Wired Intelligent Edge
  • 1.  Loop-protect best practice
    Posted Jul 23, 2018 04:13 AM
    I have switches where on the uplinks to other switches, loop-protect is enabled, and the other switches work fine (bpdu-filter/protect/admin-edge-port disabled).
    On other switches i have loop-protect specifically disabled for uplinks.
    What's the recommended best practice?
    Also a followup question regarding HP access points connected to HP/Aruba switches:
    I know i need to disable port-security on AP ports or i get into trouble with more devices connected to it (than 3 for example). Do i also need to disable bpdu-filter/protect/admin-edge port/loop-protect on these ports?
  • 2.  RE: Loop-protect best practice
    Posted Jul 24, 2018 09:45 AM
    Anyone? :)
  • 3.  RE: Loop-protect best practice
    Posted Jul 25, 2018 10:10 AM
    Hello Pepe,
    I can only speak for ourselves but we run the following configuration for all our switches, enabling it on all ports (so both uplink and edge ports) for as long as I can remember:
    loop-protect <ALL_PORT_LIST> receiver-action send-disable
    loop-protect trap loop-detected
    loop-protect transmit-interval 1 disable-timer 300
    Kind regards,
    Niels Mejan
    University of Twente
  • 4.  RE: Loop-protect best practice
    Posted Mar 25, 2019 05:40 AM
    Hello @Nelis,
    sorry for resurrecting this old thread but I was trying to optimize the loop-protect configuration on my network and I reading your statement:
    @Nelis wrote: ...enabling it on all ports (so both uplink and edge ports) for as long as I can remember:
    I've a question about using loop-protect on uplinks (where with uplink I mean inter-swtich link made via single interface or via aggregated interfaces): on interface(s) dedicated to uplink are you using the same parameter for loop-protect of edge interfaces or you experienced that other adjustments can be done with regards to action and/or disable timer values?
  • 5.  RE: Loop-protect best practice
    Posted Mar 25, 2019 06:31 AM
    Hello Parnassus,
    We use the exact same configuration for edge ports as inter-switch uplink ports. The disable-timer is a global setting so you cannot have different timers for edge or uplink ports. You can configure different actions if you would want to.
    Kind regards,
    Niels Mejan
  • 6.  RE: Loop-protect best practice
    Posted Mar 25, 2019 07:56 AM
    Yeah! good catch, correct...the disable timer is a global parameter. Thanks!
    Edit: I admit I'm still in doubt if using loop-protect on a non-edge interface (as an uplink interface is) is good or not...I've broadly read that loop-protect is designed to be used on edge interfaces, not on uplinks.
