Wired Intelligent Edge
loop-protect lab
This thread has been viewed 30 times
  • 1.  loop-protect lab
    Posted Aug 22, 2021 08:39 PM
    Although the step to "enable loop-protect to other switches" is noted in the lab guide verbally, it only demonstrates enabling it on vlan 10. For consistency, maybe show the actual command that enables it as well (loop-protect). It is shown in the Complete Configurations section. Or maybe this is by design?
    From "AOS-CX Switch Simulator - Loop Protect Lab Guide.pdf" page3
    Task 3 – Enable loop protect on Switch1
    Enable loop protect on ports to other switches, enabling it on 1 VLAN will be sufficient to detect loops
    Switch1(config)# int 1/1/2-1/1/3
    Switch1(config-if-<1/1/2-1/1/3>)# loop-protect vlan 10
    Jeff Brownell
