Hi All
I've just configured loopback detection on 5510 running 7.1.045, Release 1111P01
with the following commands
interface GigabitEthernet1/0/1
port link-mode bridge
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 111 tagged
port hybrid vlan 222 untagged
port hybrid pvid vlan 222
qos trust dscp
poe enable
loopback-detection enable vlan 222 111
loopback-detection action shutdown
ther is also a command in the global config mode:
loopback-detection interval-time 5
Now I've been testing it and the switch doesn't seem to be generating a SNMP trap, also it seems that there is some built in recovery mechanism that we have no control over.
What I mean is that when there is a loop (one cable patched into the same switch) ports involved will get shut and switch will try to bring them up after a few seconds, if the loop exists they will be shut down again. This process goes on until the loop is removed.
Now the display loopback-detection command seems to be useless here as even if there is a loop it won't show there. The only place wehre you can confirm this is dis int g1/0/1 for example.
As in oppose to comware 5 there is no loopback-detection enable multiport command available but what I need here the most is a way of seing that there is a loop in IMC rather then waiting for end users to report the problem .
Has anyone have experience with this feature on comware 7?
Some outputs from the switch while loop was created:
%Oct 13 10:51:45:437 2016 FLOOR IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is up.
%Oct 13 10:51:45:437 2016 FLOOR IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is up.
%Oct 13 10:51:45:466 2016FLOOR IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/21 link status is up.
%Oct 13 10:51:45:468 2016 FLOOR IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/21 is up.
%Oct 13 10:51:45:474 2016 FLOOR LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is mmm:aaa:ccc, Port ID is GigabitEthernet1/0/21.
%Oct 13 10:51:47:111 2016 FLOOR LPDT/4/LPDT_LOOPED: Loopback exists on GigabitEthernet1/0/21.
%Oct 13 10:51:47:116 2016 FLOOR LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port GigabitEthernet1/0/22 (IfIndex 22), Chassis ID is mmm:aaa:ccc, Port ID is GigabitEthernet1/0/21.
%Oct 13 10:51:47:126 2016 FLOOR LPDT/4/LPDT_VLAN_LOOPED: Loopback exists on GigabitEthernet1/0/21 in VLAN 111
%Oct 13 10:51:47:126 2016 FLOOR LPDT/4/LPDT_LOOPED: Loopback exists on GigabitEthernet1/0/22.
%Oct 13 10:51:47:155 2016 FLOOR IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/21 link status is down.
%Oct 13 10:51:47:157 2016 FLOOR IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/21 is down.
%Oct 13 10:51:47:164 2016 FLOOR LPDT/4/LPDT_VLAN_LOOPED: Loopback exists on GigabitEthernet1/0/22 in VLAN 111
%Oct 13 10:51:47:165 2016 FLOOR LPDT/5/LPDT_VLAN_RECOVERED: Loopback on GigabitEthernet1/0/21 in VLAN 111 recovered.
%Oct 13 10:51:47:168 2016 FLOOR LPDT/5/LPDT_RECOVERED: Loopback on GigabitEthernet1/0/21 recovered.
%Oct 13 10:51:47:196 2016 FLOOR LPDT/5/LPDT_VLAN_RECOVERED: Loopback on GigabitEthernet1/0/22 in VLAN 111 recovered.
%Oct 13 10:51:47:198 2016 FLOOR LPDT/5/LPDT_RECOVERED: Loopback on GigabitEthernet1/0/22 recovered.
%Oct 13 10:51:47:203 2016 FLOOR IFNET/3/PHY_UPDOWN: GigabitEthernet1/0/22 link status is down.
%Oct 13 10:51:47:205 2016 FLOOR IFNET/5/LINK_UPDOWN: Line protocol on the interface GigabitEthernet1/0/22 is down.
< FLOOR>dis loopback-detection
Loopback detection is enabled.
Loopback detection interval is 5 second(s).
No loopback is detected.
dis int g1/0/21
Current state: DOWN (Loopback detection down)
Line protocol state: DOWN
