Hi guys,
I have "Switch 4200G 24-Port Software Version 3Com OS V3.02.02s56". I simulated loopback ( port 7 is connected to looped unmanaged switch) . Log from switch:
#Apr 2 00:24:01:233 2000 3com-mr-bl402 DRV/5/LOOPBACKED:- 1 - Trap 1.3.6.1.4.1.43.45.1.10.2.95.1.0.3(h3cLpbkdtTrapPerVlanLoopbacked): Loopback exists on the interface 4227193 GigabitEthernet1/0/7 in VLAN 1.
%Apr 2 00:24:01:495 2000 3com-mr-bl402 DRV/5/LOOPBACK:- 1 -
Loopback does exist on port 7 vlan 1, please check it".
But the port is up and running - only warning. I want port to shutdown, but the command "loopback-detection shutdown enable" is missing.
And also another problem:
if STP is enabled, switch dosn't detect loopback on port 7,
if STP is disabled switch detects loopback.
