  • 1.  Lost WebUI after restoring flash
    Posted Apr 15, 2019 03:59 PM
    On Dell W-650, while running ArubaOS 6.4.0.1, we had a problem with Captive Portal.  In an attempt to bypass the issue and get Captive Portal working again, we booted back to our previous partition that was running 6.3.  That did not help the initial problem, so I backed up the flash to flashbackup.tar.gz, then restored to it, rebooted.  Now, the WebUI is down, and the only access I have is the CLI.
    How do you restore the WebUI from the CLI?
    Output from #show web-server:
    Web Server Configuration
    Parameter        Value
    Cipher Suite Strength                                                high
    SSL/TLS Protocol Config                                           sslv3 tlsv1
    Switch Certificate                                                       default
    Captive Portal Certificate                                           default
    Management user's WebUI access method              username/password
    User session timeout <30-3600> (seconds)              900
    Maximum supported concurrent clients <25-320>     25
    Enable WebUI access on HTTPS port (443)             false
    Web Lync Listen Protocol/Port Config                       N/A
  • 2.  RE: Lost WebUI after restoring flash
    Posted Apr 15, 2019 06:10 PM
    To be clear, you CAN get into the admin GUI or not?  Is it just the guest captive portal not working, or the administration GUI?
  • 3.  RE: Lost WebUI after restoring flash
    Posted Apr 15, 2019 06:30 PM
    Thank you for your reply!
    I have two separate issues. First, the Captive Portal stopped working when we changed the guest wireless password. And then later while attempting to fix the Captive Portal issue, my backup and restore of flash seems to have killed the WebUI. I currently have only CLI access to the controller.
    Any help would be greatly appreciated. I have been reading through the forums but none of the posts seem to mirror my issue(s).
    Thank you,
    Robert Bilow
    Golden Hour | Systems Administrator I
    858.257.0184 | robert.bilow@goldenhour.com | GoldenHour.com
    This Email may contain confidential information. If you are not the intended recipient, please delete the Email and any attachments without reading, printing, copying or forwarding it, and please notify us.
  • 4.  RE: Lost WebUI after restoring flash
    Posted Apr 16, 2019 01:21 AM
    Type "show log error all", "show log security all" and "show log system all" to see if you can get a clue what is wrong.
  • 5.  RE: Lost WebUI after restoring flash
    Posted Apr 16, 2019 10:18 AM
    Here is the output for the first command you have listed.  The LDAP errors are not concerning since we do not use that functionality.  The certificate errors make sense because this previous partition was still trying to use the self-signed certificate, which was no longer valid.  I planned on having to re-add the certificate we were using on the other ArubaOS 6.4 partition.  I did not realize the controller was rebooting itself, as shown in the first line of the output.
    (HQWLAN1) #show log error all
    Apr 16 01:37:34 <fpapps 315382> <CRIT> |fpapps|  Reboot Cause: Nanny rebooted machine - low on free memory.
    Apr 16 01:38:40 <cfgm 399816> <ERRS> |cfgm|  db_get_boc_master Unable to get Remote Node Controller INFO: Unknown column 'master_ip' in 'field list'
    Apr 16 01:38:40 <cfgm 399816> <ERRS> |cfgm|  readBocMasterUplinkConfig Unable to get Remote Node Controller uplink info
    Apr 16 01:38:43 <nanny 399816> <ERRS> |nanny|  Received the PAPI_APP_SPAWN_PROC Message
    Apr 16 01:38:59 <cfgm 399816> <ERRS> |cfgm|  db_get_boc_master Unable to get Remote Node Controller INFO: Unknown column 'master_ip' in 'field list'
    Apr 16 01:38:59 <cfgm 399816> <ERRS> |cfgm|  readBocMasterUplinkConfig Unable to get Remote Node Controller uplink info
    Apr 16 01:38:59 <cfgm 399803> <ERRS> |cfgm|  An internal system error has occurred at file ncfg_profmgr.c function ncfg_profmgr_setup_prof_socket line 532 error Unable to bind socket(/var/profmgr/cfgm): No such file or directory.
    Apr 16 01:39:04 <authmgr 132136> <CRIT> |authmgr|  Loading Certificate from /flash/webcert/cert.pem failed
    Apr 16 01:39:04 <authmgr 132144> <CRIT> |authmgr| Failed to download the cert for dot1x-termination
    Apr 16 01:39:09 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 01:39:20 <stm 304001> <ERRS> |stm|  Unexpected stm (Station management) runtime error at data_path_handler, 963, data_path_handler: recv - Network is down
    Apr 16 01:39:48 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 00:1a:1e:79:e9:02 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 00:1a:1e:79:e9:03 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:64:42 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:64:43 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 6c:f3:7f:9d:85:b2 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 6c:f3:7f:9d:85:b3 dot1x_prof-wdg44 before cert download
    Apr 16 01:41:51 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:5f:a2 dot1x_prof-wdg44 before cert download
    Apr 16 01:41:51 <authmgr 132002> <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:5f:a3 dot1x_prof-wdg44 before cert download
    Apr 16 01:54:46 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 02:10:46 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 02:26:48 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 02:42:49 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 02:59:49 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 03:16:50 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 03:33:50 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 03:50:51 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 04:07:58 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 04:25:52 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 04:43:53 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 05:01:54 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 05:10:02 <authmgr 132093> <ERRS> |authmgr|  WPA2 Key message 2 from Station b8:08:cf:4d:9b:26 6c:f3:7f:9d:85:b0 AP4 did not match the replay counter 01 vs 03
    Apr 16 05:10:02 <authmgr 132093> <ERRS> |authmgr|  WPA2 Key message 2 from Station b8:08:cf:4d:9b:26 6c:f3:7f:9d:85:b0 AP4 did not match the replay counter 03 vs 04
    Apr 16 05:19:54 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 05:28:32 <authmgr 132093> <ERRS> |authmgr|  WPA2 Key message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3 did not match the replay counter 02 vs 03
    Apr 16 05:37:54 <authmgr 199802> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
  • 6.  RE: Lost WebUI after restoring flash
    Posted Apr 16, 2019 10:21 AM
    Output from 'show log security all':
    (HQWLAN1) #show log security all
    Apr 16 01:37:32 :103093: <WARN> |ike|   Starting cryptoPOST
    Apr 16 01:39:04 :132136: <CRIT> |authmgr|  Loading Certificate from /flash/webcert/cert.pem failed
    Apr 16 01:39:04 :132144: <CRIT> |authmgr| Failed to download the cert for dot1x-termination
    Apr 16 01:39:09 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 01:39:48 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 00:1a:1e:79:e9:02 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 00:1a:1e:79:e9:03 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:64:42 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:64:43 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 6c:f3:7f:9d:85:b2 dot1x_prof-wdg44 before cert download
    Apr 16 01:39:49 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 6c:f3:7f:9d:85:b3 dot1x_prof-wdg44 before cert download
    Apr 16 01:40:02 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 01:40:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 6c:f3:7f:9d:85:b0 AP4
    Apr 16 01:41:06 :126047: <WARN> |wms| |ids| AP(00:1a:1e:79:e9:00@AP2): Signature Match: Deauth Broadcast: An AP detected a factory default signature match (Deauth-Broadcast) in a frame with BSSID 44:07:0b:26:3e:8b on channel 11 from transmitter 44:07:0b:26:3e:8b to receiver ff:ff:ff:ff:ff:ff, with SNR 6. Additional Info: SSID:. Associated WVE ID(s): WVE-2005-0019, WVE-2005-0045.
    Apr 16 01:41:12 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:64:40 AP1
    Apr 16 01:41:51 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:5f:a2 dot1x_prof-wdg44 before cert download
    Apr 16 01:41:51 :132002: <CRIT> |authmgr|  Enabling dot1x termination for AP 00:24:6c:dd:5f:a3 dot1x_prof-wdg44 before cert download
    Apr 16 01:43:17 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID da:0f:99:3f:62:33 and SSID DIRECT-33-HP M402 LaserJet on CHANNEL 1) as interfering. Additional Info: Detector-AP-Name:AP3; Detector-AP-MAC:00:24:6c:dd:5f:a0; Detector-AP-Radio:2.
    Apr 16 01:43:17 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID de:cb:bc:b5:8d:44 and SSID  on CHANNEL 1) as interfering. Additional Info: Detector-AP-Name:AP3; Detector-AP-MAC:00:24:6c:dd:5f:a0; Detector-AP-Radio:2.
    Apr 16 01:45:10 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 01:46:12 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 01:50:19 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 01:51:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 01:54:46 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 01:55:26 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 01:56:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:00:33 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:01:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:05:41 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:06:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:10:46 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 02:10:49 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:11:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:15:57 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:16:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:21:05 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:21:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:26:12 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:26:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:26:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:26:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:26:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:26:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:26:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:26:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:26:48 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 02:28:28 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:31:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:31:20 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:36:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:36:28 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:41:13 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:41:36 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:42:49 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 02:44:45 :126047: <WARN> |wms| |ids| AP(00:24:6c:dd:64:40@AP1): Signature Match: Deauth Broadcast: An AP detected a factory default signature match (Deauth-Broadcast) in a frame with BSSID 44:07:0b:26:3e:8b on channel 11 from transmitter 44:07:0b:26:3e:8b to receiver ff:ff:ff:ff:ff:ff, with SNR 7. Additional Info: SSID:. Associated WVE ID(s): WVE-2005-0019, WVE-2005-0045.
    Apr 16 02:46:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:46:43 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:51:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:51:51 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:56:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 02:56:59 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 02:57:47 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 86:96:4e:e2:04:63 and SSID ATTARBL on CHANNEL 153) as interfering. Additional Info: Detector-AP-Name:AP4; Detector-AP-MAC:6c:f3:7f:9d:85:b0; Detector-AP-Radio:1.
    Apr 16 02:59:49 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 03:01:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:02:07 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:06:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:07:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:11:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:12:22 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:12:37 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 02:8d:db:18:15:2e and SSID  on CHANNEL 11) as interfering. Additional Info: Detector-AP-Name:AP3; Detector-AP-MAC:00:24:6c:dd:5f:a0; Detector-AP-Radio:2.
    Apr 16 03:14:23 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 06:8d:db:18:15:2e and SSID  on CHANNEL 11) as interfering. Additional Info: Detector-AP-Name:AP3; Detector-AP-MAC:00:24:6c:dd:5f:a0; Detector-AP-Radio:2.
    Apr 16 03:15:39 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 88:96:4e:e2:04:63 and SSID  on CHANNEL 153) as interfering. Additional Info: Detector-AP-Name:AP4; Detector-AP-MAC:6c:f3:7f:9d:85:b0; Detector-AP-Radio:1.
    Apr 16 03:16:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:16:50 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 03:17:18 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 0c:8d:db:18:15:2e and SSID  on CHANNEL 11) as interfering. Additional Info: Detector-AP-Name:AP3; Detector-AP-MAC:00:24:6c:dd:5f:a0; Detector-AP-Radio:2.
    Apr 16 03:17:30 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:18:35 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 0a:8d:db:18:15:2e and SSID  on CHANNEL 11) as interfering. Additional Info: Detector-AP-Name:AP3; Detector-AP-MAC:00:24:6c:dd:5f:a0; Detector-AP-Radio:2.
    Apr 16 03:19:44 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:21:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:22:38 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:26:14 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:27:46 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:28:29 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:31:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:32:54 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:33:50 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 03:36:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:38:01 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:41:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:43:09 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:46:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:48:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:50:51 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 03:51:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:53:25 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 03:56:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 03:58:33 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:01:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:03:40 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:06:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:07:58 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 04:08:49 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:11:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:13:56 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:16:15 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:17:27 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 88:96:4e:e2:04:63 and SSID  on CHANNEL 153) as interfering. Additional Info: Detector-AP-Name:AP4; Detector-AP-MAC:6c:f3:7f:9d:85:b0; Detector-AP-Radio:1.
    Apr 16 04:19:05 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:21:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:22:37 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID d8:61:62:0b:07:e4 and SSID ClickShare-ShowRoom on CHANNEL 1) as interfering. Additional Info: Detector-AP-Name:AP2; Detector-AP-MAC:00:1a:1e:79:e9:00; Detector-AP-Radio:2.
    Apr 16 04:25:52 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 04:26:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:28:29 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:29:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:31:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:64:40 AP1
    Apr 16 04:34:25 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:36:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:36:49 :126005: <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID 86:96:4e:67:61:d3 and SSID ATT5zseiVS on CHANNEL 161) as interfering. Additional Info: Detector-AP-Name:AP4; Detector-AP-MAC:6c:f3:7f:9d:85:b0; Detector-AP-Radio:1.
    Apr 16 04:39:33 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:41:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:43:53 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 04:46:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:49:47 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:51:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:51:47 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 00:24:6c:dd:64:42 AP1
    Apr 16 04:54:54 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 04:56:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 04:59:40 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:00:02 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:01:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:01:54 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 05:05:10 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:05:44 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:06:16 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:07:56 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station a0:cc:2b:1b:a9:9b 00:24:6c:dd:64:42 AP1
    Apr 16 05:10:02 :132093: <ERRS> |authmgr|  WPA2 Key message 2 from Station b8:08:cf:4d:9b:26 6c:f3:7f:9d:85:b0 AP4 did not match the replay counter 01 vs 03
    Apr 16 05:10:02 :132093: <ERRS> |authmgr|  WPA2 Key message 2 from Station b8:08:cf:4d:9b:26 6c:f3:7f:9d:85:b0 AP4 did not match the replay counter 03 vs 04
    Apr 16 05:10:18 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:11:09 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:11:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:14:19 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station a0:cc:2b:1b:a9:9b 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:16:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:18:43 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:19:54 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 05:20:32 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:21:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:24:52 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station a0:cc:2b:1b:a9:9b 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:25:40 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:25:40 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:25:41 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:25:41 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:25:42 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:25:42 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:25:43 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:25:43 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:26:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:28:30 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:28:32 :132093: <ERRS> |authmgr|  WPA2 Key message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3 did not match the replay counter 02 vs 03
    Apr 16 05:28:32 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:54:51:5c:8d:70 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:30:28 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station a0:cc:2b:1b:a9:9b 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:30:48 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:31:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:33:08 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:35:55 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:36:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:36:39 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station a0:cc:2b:1b:a9:9b 00:24:6c:dd:64:42 AP1
    Apr 16 05:37:54 :199802: <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:879: LDAP Server HQDC1rad: Error in Binding Admin to server: Probably error in credentials
    Apr 16 05:40:11 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
    Apr 16 05:41:03 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station b8:27:eb:2e:bc:1e 00:24:6c:dd:64:40 AP1
    Apr 16 05:41:17 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station bc:d7:13:00:0b:12 00:24:6c:dd:5f:a0 AP3
    Apr 16 05:41:59 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station a0:cc:2b:1b:a9:9b 00:24:6c:dd:64:42 AP1
    Apr 16 05:45:11 :132093: <ERRS> |authmgr|  WPA2 Key message 2 from Station b8:08:cf:3d:46:b8 6c:f3:7f:9d:85:b0 AP4 did not match the replay counter 01 vs 02
    Apr 16 05:45:40 :132094: <WARN> |authmgr|  MIC failed in WPA2 Key Message 2 from Station 00:9d:6b:11:71:7c 6c:f3:7f:9d:85:b2 AP4
  • 7.  RE: Lost WebUI after restoring flash
    Posted Apr 16, 2019 10:22 AM
    Output of 'show log system all':
    (HQWLAN1) # show log system all
    Apr 16 01:37:34 :315382: <CRIT> |fpapps|  Reboot Cause: Nanny rebooted machine - low on free memory.
    Apr 16 01:37:35 :316001: <WARN> |wms| Waiting for dbstart...
    Apr 16 01:37:36 :304044: <WARN> |stm| Waiting for dbstart...
    Apr 16 01:37:37 :316001: <WARN> |wms| Waiting for dbstart...
    Apr 16 01:37:37 :304044: <WARN> |stm| Waiting for dbstart...
    Apr 16 01:37:38 :316001: <WARN> |wms| Waiting for dbstart...
    Apr 16 01:37:38 KERNEL: klogd started: BusyBox v1.01 (2014.08.22-00:09+0000)
    Apr 16 01:37:38 KERNEL: 0:
    Apr 16 01:37:38 KERNEL: Dell
    Apr 16 01:37:38 KERNEL: ArubaOS Version 6.3.1.10 (build 45532 / label #45532)
    Apr 16 01:37:38 KERNEL: Built by p4build@majorca.arubanetworks.com on 2014-08-21 at 17:19:51 PDT (gcc version 3.4.3)
    Apr 16 01:37:38 KERNEL: 0:Using default Mac address
    Apr 16 01:37:38 KERNEL: 0:XLR Physical Address Exclude Region: 0x1c00000
    Apr 16 01:37:38 KERNEL: 0:L1_WAY_MASK: 0: l:3f s:c0 f:0 i:c03f3f3f d:3fc0c0c0
    Apr 16 01:37:38 KERNEL: 0:L1_WAY_MASK: 1: l:0 s:3 f:fc i:fcfcfc03 d: 30303fc
    Apr 16 01:37:38 KERNEL: 0:[xlr_enable_unaligned_access]: Enabling unaligned access L1D_CONFIG0: 0x403f
    Apr 16 01:37:38 KERNEL: 0:prom_init: envp[0] = [BOARD=ARIZONA]
    Apr 16 01:37:38 KERNEL: 0:<5>248MB HIGHMEM available.
    Apr 16 01:37:38 KERNEL: 0:<7>On node 0 totalpages: 194560
    Apr 16 01:37:38 KERNEL: 0:<7>  DMA zone: 131072 pages, LIFO batch:31
    Apr 16 01:37:38 KERNEL: 0:<7>  DMA32 zone: 0 pages, LIFO batch:0
    Apr 16 01:37:38 KERNEL: 0:<7>  Normal zone: 0 pages, LIFO batch:0
    Apr 16 01:37:38 KERNEL: 0:<7>  HighMem zone: 63488 pages, LIFO batch:15
    Apr 16 01:37:38 KERNEL: 0:(PROM) CPU present map: 7 SOS_CPU_MAP: 0xf8 online CPUs: 0xff cli_cpu:3
    Apr 16 01:37:38 KERNEL: 0:Phys CPU present map: 7, possible map 7
    Apr 16 01:37:38 KERNEL: 0:Detected 2 Slave CPU(s)
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-base init
    Apr 16 01:37:38 KERNEL: 0:Primary instruction cache 32kB, 8-way, linesize 32 bytes.
    Apr 16 01:37:38 KERNEL: 0:Primary data cache 32kB 8-way, linesize 32 bytes.
    Apr 16 01:37:38 KERNEL: 0:Setting up NMI Handler for Axxx platforms
    Apr 16 01:37:38 KERNEL: 0:mips_hpt_frequency = 600000000
    Apr 16 01:37:38 KERNEL: 0:Using 600.000 MHz high precision timer. cycles_per_jiffy=6000000
    Apr 16 01:37:38 KERNEL: 0:phoenix_timer_setup: non_core_cpus:2 Maxval:51615 mask:6
    Apr 16 01:37:38 KERNEL: 0:phoenix_timer_setup: phoenix_timer_stats = 8303ea20, phoenix_timer_diff = 8303ea40,
    Apr 16 01:37:38 KERNEL:     phoenix_timer_count = 8303ea60, phoenix_timer_epc = 8303ea80,
    Apr 16 01:37:38 KERNEL:     phoenix_timer_cpu = 8303eaa0, phoenix_timer_gettimeoffset = 8303eac0
    Apr 16 01:37:38 KERNEL:     max_val[0] = a2c2a, max_val[others] = 51615,
    Apr 16 01:37:38 KERNEL: 0:<6>Memory: 384196k/252416k available (4430k kernel code, 56300k reserved, 1168k data, 42776k init, 188416k highmem)
    Apr 16 01:37:38 KERNEL: 0:<7>Calibrating delay loop... 0:133.12 BogoMIPS (lpj=665600)
    Apr 16 01:37:38 KERNEL: 0:<6>Security Framework v1.0.0 initialized
    Apr 16 01:37:38 KERNEL: 0:<6>Capability LSM initialized
    Apr 16 01:37:38 KERNEL: 0: available.
    Apr 16 01:37:38 KERNEL: 0:(PROM): waking up phys cpu# 1, bucket_1, gp = 838cc000
    Apr 16 01:37:38 KERNEL: 0:(PROM): sent a wakeup message to bucket 1
    Apr 16 01:37:38 KERNEL: 1:Initializing CPU:0 (1), current=838a6048, gp = 838cc000
    Apr 16 01:37:38 KERNEL: 1:<7>Calibrating delay loop... 1:138.44 BogoMIPS (lpj=692224)
    Apr 16 01:37:38 KERNEL: 0:(PROM): waking up phys cpu# 2, bucket_2, gp = 838d6000
    Apr 16 01:37:38 KERNEL: 0:(PROM): sent a wakeup message to bucket 2
    Apr 16 01:37:38 KERNEL: 2:Initializing CPU:0 (2), current=838ad028, gp = 838d6000
    Apr 16 01:37:38 KERNEL: 2:<7>Calibrating delay loop... 2:197.42 BogoMIPS (lpj=987136)
    Apr 16 01:37:38 KERNEL: 2:<7>Calibrating delay loop... 2:197.83 BogoMIPS (lpj=989184)
    Apr 16 01:37:38 KERNEL: 0:<6>Brought up 3 CPUs
    Apr 16 01:37:38 KERNEL: 1:migration_cost=1:100001:
    Apr 16 01:37:38 KERNEL: 0:<5>detected lzma initramfs
    Apr 16 01:37:38 KERNEL: 0:<5>initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=14555648
    Apr 16 01:37:38 KERNEL: 0:<5>LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> 0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:.0:
    Apr 16 01:37:38 KERNEL: 0:[pcibios_init]: IO-Remapped phys=10000000, size=1000000 to vaddr=b0000000
    Apr 16 01:37:38 KERNEL: 0:[pcibios_init]: IO-Remapped phys=15000000, size=100000 to vaddr=b5000000
    Apr 16 01:37:38 KERNEL: 0:Registering XLR/XLS PCIX/PCIE Controller.
    Apr 16 01:37:38 KERNEL: 0:<5>SCSI subsystem initialized
    Apr 16 01:37:38 KERNEL: 0: ******* PCI-PHOENIX SETTING UP B0 DEVICE *******
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facilities init
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-heartbeat init
    Apr 16 01:37:38 KERNEL: 0:highmem bounce pool size: 64 pages
    Apr 16 01:37:38 KERNEL: 0:<6>JFFS2 version 2.2. (NAND) (SUMMARY)  (C) 2001-2003 Red Hat, Inc.
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-core init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-fs init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-ipc init in kernel
    Apr 16 01:37:38 KERNEL: nel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-kernel init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-locking init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-memory init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-network init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-process init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-socket init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-timer init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-statedump init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-facility-network_ip_interface init in kernel
    Apr 16 01:37:38 KERNEL: 0:<6>LTT : ltt-core init as module
    Apr 16 01:37:38 KERNEL: 0:<6>ltt-control init
    Apr 16 01:37:38 KERNEL: 0:<6>hw_random hardware driver 1.0.0 loaded
    Apr 16 01:37:38 KERNEL: 0:Registered XLR tracebuffer driver with Major No. [0]
    Apr 16 01:37:38 KERNEL: 0:xlrinfo_init: BEGIN RMIINFO_INIT
    Apr 16 01:37:38 KERNEL: 0:Registered sos console serial driver
    Apr 16 01:37:38 KERNEL: 0:Running on Grenache. Assuming the slot id is 3
    Apr 16 01:37:38 KERNEL: 0:Coredump handling done by CPU2
    Apr 16 01:37:38 KERNEL: 0:Function [virtual_uart_init]Loader support not enabled. Returning from virtual_uart_init
    Apr 16 01:37:38 KERNEL: 0:RAMDISK driver initialized: 16 RAM disks of 87040K size 1024 blocksize
    Apr 16 01:37:38 KERNEL: 0:Layer 2 interface driver inited
    Apr 16 01:37:38 KERNEL: 0:<6>Ethernet Channel Bonding Driver: v3.0.1 (January 9, 2006)
    Apr 16 01:37:38 KERNEL: 0:<4>bonding: Warning: either miimon or arp_interval and arp_ip_target module parameters must be specified, otherwise bonding will not detect link failures! see bonding.txt for details.
    Apr 16 01:37:38 KERNEL: 0:[user_mac_init]: user_mac_data=0x52ed28, psb_shm_size=0x800000
    Apr 16 01:37:38 KERNEL: 0:Registered phoenix user_mac driver: major=0
    Apr 16 01:37:38 KERNEL: 0:Registering sos_msg_driver
    Apr 16 01:37:38 KERNEL: 0:Regsitering for cpus in mask:0xe0 from 0 to 2
    Apr 16 01:37:38 KERNEL: 0:Registered msgring handler for cpu station 1
    Apr 16 01:37:38 KERNEL: 0:rtgw_tunnel_init
    Apr 16 01:37:38 KERNEL: 0:<6>PPP generic driver version 2.4.2
    Apr 16 01:37:38 KERNEL: 0:<6>PPP Deflate Compression module registered
    Apr 16 01:37:38 KERNEL: 0:<6>PPP BSD Compression module registered
    Apr 16 01:37:38 KERNEL: 0:<5>physmap flash device: 400000 at 1c000000
    Apr 16 01:37:38 KERNEL: 0:<6>phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
    Apr 16 01:37:38 KERNEL: 0: Amd/Fujitsu Extended Query Table at 0x0040
    Apr 16 01:37:38 KERNEL: 0:<4>phys_mapped_flash: CFI does not contain boot bank location. Assuming top.
    Apr 16 01:37:38 KERNEL: 0:<5>number of CFI chips: 1
    Apr 16 01:37:38 KERNEL: 0:Parsing the partition  info
    Apr 16 01:37:38 KERNEL: 0:Adding partitions...
    Apr 16 01:37:38 KERNEL: 0:<5>Using physmap partition definition
    Apr 16 01:37:38 KERNEL: 0:<5>Creating 1 MTD partitions on "phys_mapped_flash":
    Apr 16 01:37:38 KERNEL: 0:<5>0x00000000-0x00200000 : "Flash"
    Apr 16 01:37:38 KERNEL: 0:NAND RDY/BSY support detected
    Apr 16 01:37:38 KERNEL: 0:<6>NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron NAND 256MiB 3,3V 16-bit)
    Apr 16 01:37:38 KERNEL: 0:<6>Scanning device for bad blocks
    Apr 16 01:37:38 KERNEL: 0:NAND using OLD partition map
    Apr 16 01:37:38 KERNEL: 0:<5>Creating 3 MTD partitions on "xls-nand":
    Apr 16 01:37:38 KERNEL: 0:<5>0x00000000-0x03200000 : "image0"
    Apr 16 01:37:38 KERNEL: 0:<5>0x03200000-0x06400000 : "image1"
    Apr 16 01:37:38 KERNEL: 0:<5>0x06400000-0x10000000 : "ffs"
    Apr 16 01:37:38 KERNEL: 0:<6>ehci-xls ehci-xls.0: XLS EHCI Host Controller
    Apr 16 01:37:38 KERNEL: 0:<6>ehci-xls ehci-xls.0: new USB bus registered, assigned bus number 1
    Apr 16 01:37:38 KERNEL: 0:<6>ehci-xls ehci-xls.0: irq 39, io mem 0x1ef24000
    Apr 16 01:37:38 KERNEL: 0:<6>ehci-xls ehci-xls.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
    Apr 16 01:37:38 KERNEL: 0:USB Device: 0x00000000
    Apr 16 01:37:38 KERNEL: 0:USB Product: XLS EHCI Host Controller
    Apr 16 01:37:38 KERNEL: 0:USB Manufacturer: Linux 2.6.16 ehci_hcd
    Apr 16 01:37:38 KERNEL: 0:USB SerialNumber: ehci-xls
    Apr 16 01:37:38 KERNEL: 0:<6>usb usb1: c->desc.bMaxPower 0, udev->busmA 0
    Apr 16 01:37:38 KERNEL: 0:<6>usb usb1: configuration #1 chosen from 1 choice
    Apr 16 01:37:38 KERNEL: 0:<6>hub 1-0:1.0: USB hub found
    Apr 16 01:37:38 KERNEL: 0:<6>hub 1-0:1.0: 2 ports detected
    Apr 16 01:37:38 KERNEL: 0:<7>ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
    Apr 16 01:37:38 KERNEL: 0:<6>ohci-xls ohci-xls.1: XLS OHCI Host Controller
    Apr 16 01:37:38 KERNEL: 0:<6>ohci-xls ohci-xls.1: new USB bus registered, assigned bus number 2
    Apr 16 01:37:38 KERNEL: 0:<6>ohci-xls ohci-xls.1: irq 39, io mem 0x1ef24400
    Apr 16 01:37:38 KERNEL: 0:USB Product: XLS OHCI Host Controller
    Apr 16 01:37:38 KERNEL: 0:USB Manufacturer: Linux 2.6.16 ohci_hcd
    Apr 16 01:37:38 KERNEL: 0:USB SerialNumber: ohci-xls
    Apr 16 01:37:38 KERNEL: 0:<6>usb usb2: c->desc.bMaxPower 0, udev->busmA 0
    Apr 16 01:37:38 KERNEL: 0:<6>usb usb2: configuration #1 chosen from 1 choice
    Apr 16 01:37:38 KERNEL: 0:<6>hub 2-0:1.0: USB hub found
    Apr 16 01:37:38 KERNEL: 0:<6>hub 2-0:1.0: 1 port detected
    Apr 16 01:37:38 KERNEL: 0:<6>ohci-xls ohci-xls.2: XLS OHCI Host Controller
    Apr 16 01:37:38 KERNEL: 0:<6>ohci-xls ohci-xls.2: new USB bus registered, assigned bus number 3
    Apr 16 01:37:38 KERNEL: 0:<6>ohci-xls ohci-xls.2: irq 39, io mem 0x1ef24800
    Apr 16 01:37:38 KERNEL: : c->desc.bMaxPower 0, udev->busmA 0
    Apr 16 01:37:38 KERNEL: 0:<6>usb usb3: configuration #1 chosen from 1 choice
    Apr 16 01:37:38 KERNEL: 0:<6>hub 3-0:1.0: USB hub found
    Apr 16 01:37:38 KERNEL: 0:<6>hub 3-0:1.0: 1 port detected
    Apr 16 01:37:38 KERNEL: 0:<6>usb 1-1: new high speed USB device using ehci-xls and address 2
    Apr 16 01:37:38 KERNEL: 0:<6>USB Universal Host Controller Interface driver v2.3
    Apr 16 01:37:38 KERNEL: 0:USB Device: 0x05e30607
    Apr 16 01:37:38 KERNEL: 0:USB Product: USB2.0 Hub
    Apr 16 01:37:38 KERNEL: 0:USB Manufacturer: <NULL>
    Apr 16 01:37:38 KERNEL: 0:USB SerialNumber: <NULL>
    Apr 16 01:37:38 KERNEL: 0:<6>usb 1-1: c->desc.bMaxPower 50, udev->busmA 500
    Apr 16 01:37:38 KERNEL: 0:<6>usb 1-1: configuration #1 chosen from 1 choice
    Apr 16 01:37:38 KERNEL: 0:<6>hub 1-1:1.0: USB hub found
    Apr 16 01:37:38 KERNEL: 0:<6>hub 1-1:1.0: 4 ports detected
    Apr 16 01:37:38 KERNEL: 0:<6>drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
    Apr 16 01:37:38 KERNEL: 0:<6>Initializing USB Mass Storage driver...
    Apr 16 01:37:38 KERNEL: 0:<6>USB Mass Storage support registered.
    Apr 16 01:37:38 KERNEL: 0:Intializing BK-3220 I2C Host Adapter...0:done.
    Apr 16 01:37:38 KERNEL: 0:i2c-palm-bk3220: Added I2C Bus 0
    Apr 16 01:37:38 KERNEL: 0:i2c-palm-bk3220: Added I2C Bus 1
    Apr 16 01:37:38 KERNEL: 0:<6>i2c-grenache: using default base 0xbd000000
    Apr 16 01:37:38 KERNEL: 0:Registering powr6at6 I2C Power Trim Controller driver
    Apr 16 01:37:38 KERNEL: 0:Found POWR6AT6 on Palm Chip BK3220 Adapter 0
    Apr 16 01:37:38 KERNEL: 0:Found POWR6AT6 on Grenache I2C_0
    Apr 16 01:37:38 KERNEL: 0:Registering max6640 I2C based Temperature Sensor driver...
    Apr 16 01:37:38 KERNEL: 0:Found MAX6640 on Grenache I2C_0
    Apr 16 01:37:38 KERNEL: 0:Registering Phoenix I2C based RTC driver...
    Apr 16 01:37:38 KERNEL: 0:<6>: Found DS1374 on Palm Chip BK3220 Adapter 0
    Apr 16 01:37:38 KERNEL: 0:Registering Phoenix I2C based TPM driver...
    Apr 16 01:37:38 KERNEL: 0:Registering Broadcom I2C POE driver...
    Apr 16 01:37:38 KERNEL: 0:<6>: Found BCM59103 on Grenache I2C_0
    Apr 16 01:37:38 KERNEL: 0:<6>: Found BCM59103 on Grenache I2C_1
    Apr 16 01:37:38 KERNEL: 0:<6>lo: Disabled Privacy Extensions
    Apr 16 01:37:38 KERNEL: 0:<6>IPv6 over IPv4 tunneling driver
    Apr 16 01:37:38 KERNEL: 0:<6>802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
    Apr 16 01:37:38 KERNEL: 0:<6>All bugs added by David S. Miller <davem@redhat.com>
    Apr 16 01:37:38 KERNEL: 0:Starting Kernel AESGCM KAT ...0:Completed Kernel AESGCM KAT
    Apr 16 01:37:38 KERNEL: 2:flushing more than page size of icache addresses starting @ c007f000
    Apr 16 01:37:38 KERNEL: 2:<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
    Apr 16 01:37:38 KERNEL: 2:<6>drivers/usb/serial/usb-serial.c: USB Serial Driver core
    Apr 16 01:37:38 KERNEL: 1:<4>process `syslogd' is using obsolete setsockopt SO_BSDCOMPAT
    Apr 16 01:37:38 KERNEL: 1:<4>process `soed' is using obsolete setsockopt SO_BSDCOMPAT
    Apr 16 01:37:38 :304044: <WARN> |stm| Waiting for dbstart...
    Apr 16 01:37:39 :316001: <WARN> |wms| Waiting for dbstart...
    Apr 16 01:37:39 :304044: <WARN> |stm| Waiting for dbstart...
    Apr 16 01:37:40 :316001: <WARN> |wms| Waiting for dbstart...
    Apr 16 01:37:40 :304044: <WARN> |stm| Waiting for dbstart...
    Apr 16 01:38:40 :399816: <ERRS> |cfgm|  db_get_boc_master Unable to get Remote Node Controller INFO: Unknown column 'master_ip' in 'field list'
    Apr 16 01:38:40 :399816: <ERRS> |cfgm|  readBocMasterUplinkConfig Unable to get Remote Node Controller uplink info
    Apr 16 01:38:43 :306510: <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
    Apr 16 01:38:43 :306510:  <WARN> |publisher|  Dropping message from 8212 for service '75 (service not found)'
    Apr 16 01:38:43 :399816: <ERRS> |nanny|  Received the PAPI_APP_SPAWN_PROC Message
    Apr 16 01:38:46 :306510: <WARN> |publisher|  Dropping message from 8343 for service 'certmgr-certchange (service not found)'
    Apr 16 01:38:46 :306510: <WARN> |publisher|  Dropping message from 8359 for service 'dhcpd config status (service not found)'
    Apr 16 01:38:47 :306510: <WARN> |publisher|  Dropping message from 8343 for service 'certmgr-certchange (service not found)'
    Apr 16 01:38:56 KERNEL: 2:<4>process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    Apr 16 01:38:59 KERNEL: 1:flushing more than page size of icache addresses starting @ c0079000
    Apr 16 01:38:59 KERNEL: 1:<6>cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
    Apr 16 01:38:59 KERNEL: 0:flushing more than page size of icache addresses starting @ c00cf000
    Apr 16 01:38:59 KERNEL: 0:<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
    Apr 16 01:38:59 KERNEL: 0:<6>drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.1
    Apr 16 01:38:59 KERNEL: 0:flushing more than page size of icache addresses starting @ c00ca000
    Apr 16 01:38:59 :399816: <ERRS> |cfgm|  db_get_boc_master Unable to get Remote Node Controller INFO: Unknown column 'master_ip' in 'field list'
    Apr 16 01:38:59 :399816: <ERRS> |cfgm|  readBocMasterUplinkConfig Unable to get Remote Node Controller uplink info
    Apr 16 01:38:59 KERNEL: 0:<6>drivers/usb/serial/usb-serial.c: USB Serial support registered for Sierra USB modem
    Apr 16 01:38:59 KERNEL: 0:<6>drivers/usb/serial/sierra.c: USB Driver for Sierra Wireless USB modems: v.1.7.40
    Apr 16 01:38:59 KERNEL: 0:flushing more than page size of icache addresses starting @ c00e1000
    Apr 16 01:38:59 KERNEL: 0:<4>hso: Ignoring new-style parameters in presence of obsolete ones
    Apr 16 01:38:59 KERNEL: 0:<6>hso: drivers/usb/serial/hso.c: 1.2 Option Wireless
    Apr 16 01:38:59 KERNEL: 0:<6>hso: Registering procfs
    Apr 16 01:38:59 :399803: <ERRS> |cfgm|  An internal system error has occurred at file ncfg_profmgr.c function ncfg_profmgr_setup_prof_socket line 532 error Unable to bind socket(/var/profmgr/cfgm): No such file or directory.
    Apr 16 01:39:05 KERNEL: 1:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
    Apr 16 01:39:09 :306510: <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
    Apr 16 01:39:20 :304001: <ERRS> |stm|  Unexpected stm (Station management) runtime error at data_path_handler, 963, data_path_handler: recv - Network is down
    Apr 16 01:39:24 :303022: <WARN> |AP AP2@192.168.150.250 nanny|  Reboot Reason: No reboot message found.
    Apr 16 01:39:25 :303022: <WARN> |AP AP1@192.168.150.249 nanny|  Reboot Reason: No reboot message found.
    Apr 16 01:39:26 :303022: <WARN> |AP AP4@192.168.150.248 nanny|  Reboot Reason: No reboot message found.
    Apr 16 01:40:02 :306510: <WARN> |publisher|  Dropping message from 8212 for service '77 (service not found)'
    Apr 16 01:40:30 :303022: <WARN> |AP AP3@192.168.150.251 nanny|  Reboot Reason: AP rebooted Fri Dec 31 16:01:12 PST 1999; failed to get master-ip
  • 8.  RE: Lost WebUI after restoring flash
    Posted Apr 16, 2019 03:06 AM
    There have been flash space constraints on the 620/650 controllers where (documented in release notes) you had to upgrade the same firmware twice. During the first upgrade, there was insufficient flash space available, after the second you gained back the WebUI.
    What you can try is to reflash the exact same firmware that you are using via the CLI and TFTP to see if that helps.
  • 9.  RE: Lost WebUI after restoring flash
    Posted Apr 16, 2019 07:40 AM
    Herman, the OP said that he or she was having issues before the flash was restored. The Op did not upgrade the firmware.  Also if the user needed to upgrade the second partition, when the user SSHs in or logs into the GUI, it would say so.  I am more curious if there is anythig in the logs that would indicate what is going wrong here.
