  • 1.  low price compatible switch
    Posted May 20, 2012 03:36 AM
    Hi All,
    I am trying to setup a network with 14- AP-93 , 1- 650 controller.
    Basically internet access is desired using MAC and captive portal auth using Internal DB.
    I have to suggest a low price  PoE Switch to customer.
    I am thinking of  Dlink   DES-1210-28P  24 Port switch
     ftp://support.dlink.co.in/pdfs/products/DES-1210-28P/DES-1210-28P_ds.pdf
    It has PoE Budget 193 Watts, 802.1x feature.
    any other suggestions ?? any compatibility issue ??
  • 2.  RE: low price compatible switch
    Posted May 23, 2012 10:11 AM
    AP-93 power draw is 10W and that D-Link seems to be pushing 15.4W trough every port so I don't see why it wouldn't work. Cheap stuff usually has 100Mbit ports like in this case. I've used some cheap-ass Zyxel, A-Link, Netgear stuff, the power feeding works ok and I don't bother with other possible features. Quality of these devices is what is, got pile of broken PoE injectors.
