Comware
LX vs LH GBIC
  • 1.  LX vs LH GBIC
    Posted Jul 19, 2006 09:02 AM
    I have a 4108 and I need to install another GBIC, 1st what is the difference between a LX and LH GBIC, second, how can I tell which I already have in my switch?
  • 2.  RE: LX vs LH GBIC
    Posted Jul 19, 2006 09:34 AM
    Hi
    The difference in Cabling,
    LX-LC
    * Either single mode or multimode
    * 62.5/125 µm or 50/125 µm (core/cladding) diameter, graded-index, low metal content, multimode fiber optic, complying with ITU-T G.651 and ISO/IEC 793-2 Type A1b or A1a, respectively
    * Low metal content, single-mode fiber-optic, complying with ITU-T G.652 and ISO/IEC 793-2 Type B1
    Maximum distance: 10 km (single mode) or 550 m (multimode).
    LX-LC
    Maximum distance: 70 km
    For more information:
    http://www.hp.com/rnd/products/switches/switch4100glseries/accessories.htm
    If you want to know what do you have in your switch, it depends on the Modules that you have, BUT :
    I prefer to use the HP ProCurve Configurator, so you can simulate what do you have and know better about the Option you have:
    http://www.hp.com/rnd/configurator.htm
    Download this software and you can know easily what exactly do you have.
    Don;t forget to assign points.
    Good Luck !!!
  • 3.  RE: LX vs LH GBIC
    Posted Jul 19, 2006 10:23 AM
