I have a case where I would like to authenticate some devices that can't speak RADIUS, with MAC-Auth instead. I have both profiles enabled in my AAA-profile and i can see in the logs that the device passes MAC-Auth, but then continuing on failing the 802.1X Auth.
To my question:
Is it possible to make a solution where if MAC-Auth passes, the authentication process won't continue to 802.1x? In other word: If either MAC-Auth OR 802.1x-Auth passes, user gets authenticated.
Thanks in advice!
