  • 1.  mac cache setting missing from web page
    Posted Feb 27, 2015 12:29 PM
    in the older versions of clearpass there was a post-auth setting for guest MAC caching. Now in 6.5 its gone. Whats the workaround?
  • 2.  RE: mac cache setting missing from web page
    Posted Feb 27, 2015 12:30 PM
    There is a service template for MAC caching now.
    I'm not sure what you are referring to.
  • 3.  RE: mac cache setting missing from web page
    Posted Feb 27, 2015 12:36 PM
    My routine in the past was to setup the mac cache service template, then go to the guest web page and select the option "register the guests mac address with policy manager" That setting was under post-authentication. Its not there now
  • 4.  RE: mac cache setting missing from web page
    Posted Feb 27, 2015 12:38 PM
    Those settings were not used for MAC caching (although I supposed some of
    them would work). I would use the MAC-caching service template.
  • 5.  RE: mac cache setting missing from web page
    Posted Feb 27, 2015 12:41 PM
    Does the mac caching service need to be ordered above or below the guest service?
  • 6.  RE: mac cache setting missing from web page
    Posted Feb 27, 2015 12:43 PM
    Doesn't matter. It checks different attributes. I always put it above the
    guest web-login service solely because the MAC-auth happens first.
  • 7.  RE: mac cache setting missing from web page
    Posted Mar 05, 2015 02:12 PM
    Thank you. That worked
