Hello Michael,
I'm still struggling to see how I can do this using the API, I looked at:
/object/clr_gapdb_ap_lms
But that runs
clear gap-db stale-ap ap-name <ap name> lms lms-ip <lms ip>
which seems to be to do with removing old entries from an md where the databases have become out of sync.
I just want to run "clear gap-db wired-mac <ap-mac>" via the API, is that possible?
Guy
Guy Goodrick
Original Message:
Sent: May 18, 2021 03:34 AM
Subject: Manage AP whitelist and AP database using API
There is an API to remove from whitelist.
/object/wdb_cpsec_del_mac
Michael Clarke (Aruba)
Original Message:
Sent: May 17, 2021 05:49 AM
Hi Michael,
Thanks - that's useful. But I can't see similar commands to remove APs from the whitelist, or am I missing something?
Guy
Guy Goodrick
Original Message:
Sent: May 17, 2021 01:50 AM
Guy,
Yes, there are a few there. Look in the 'AP Provisioning' container for the APIs. A few I can see
/object/wdb_cpsec_add_mac
/object/wdb_cpsec_modify_mac
Original Message:
Sent: May 16, 2021 02:27 PM
Is it possible to manage the AP whitelist and AP database using the API (ie delete APs from them)?
Thank you,
Guy
Guy Goodrick
