Manage IAPs in groups/templates
  • 1.  Manage IAPs in groups/templates
    Posted Jul 19, 2012 10:39 PM
    Can AMP be used to manage large numbers of IAP clusters in groups or by using templates.  I know this is possible with AMP management of ArubaOS controllers, but I am curious is the same is possible with IAP.  Thank you!
  • 2.  RE: Manage IAPs in groups/templates
    Posted Jul 20, 2012 06:21 PM
    Yes, it is possible. When you add the first instant network to AirWave, it will pull in the config from the virtual controller and populate the template on the Group Templates page for that instant network.  The workflow is that you will set up one instant network to the desired configuration and use that to push it to other instant networks. I am attaching an early version of the Instant deployment guide. Please let me know if you have any comments on the document. I am hoping it will be useful while you are configuring the Instant networks.
    Sujatha
    Attachment(s)
