  • 1.  Managing IAP-VPN AP's from Airwave
    Posted Mar 20, 2014 11:40 AM
    I want to start deploying IAP-VPN configured Instant AP's to some of our home users.
    I have been testing this in our lab and have the IAP configured to connect to our Airwave server, where the config is pushed down to it via Instant GUI config.
    This all works pretty well.
    The issue is that when the IAP is sent to the home user, the IAP's IP address is now different and Airwave is no longer able to contact it and classes it as down.
    I am able to connect to the IAP remotely by https to the inner IP of the VPN tunnel, but I need to be able to get to it from Airwave so that if we need to push out a change across multiple IAP's it can be done one time only without the need to login to each IAP.
    I woud appreciate some help in working this out
  • 2.  RE: Managing IAP-VPN AP's from Airwave
    Posted Mar 20, 2014 12:27 PM
    I'll have someone run through this in the lab and then update.
  • 3.  RE: Managing IAP-VPN AP's from Airwave
    Posted Mar 20, 2014 10:39 PM
    if IAP can ping airwave? can we get IAP's running config?
  • 4.  RE: Managing IAP-VPN AP's from Airwave
    Posted Mar 21, 2014 01:11 AM
    we are trying to reproduce the issue, will update then.
  • 5.  RE: Managing IAP-VPN AP's from Airwave
    Posted Mar 24, 2014 06:55 AM
    Here's my IAP config
    18:64:72:c5:49:c4# sh run
    version 6.3.1.0-4.0.0
    virtual-controller-country GB
    virtual-controller-key 573d3cc301f2d17e5f2d3dcf51a7231da78b0f63e2c5b53c6b
    name e17447
    organization EMEA-IAP
    virtual-controller-ip 172.18.109.1
    syslog-server 10.101.1.243
    terminal-access
    ntp-server 172.17.0.1
    clock timezone none 00 00
    rf-band all
    ams-ip 10.101.1.243
    ams-key b6ce5a0e3999a796d6a5bf45a9a13270
    ams-identity 844460756981198a0fa95e406bd32caf
    allowed-ap 18:64:72:c5:49:c4
    routing-profile
     route  0.0.0.0  0.0.0.0  <controller public IP>
    snmp-server community a71f5328091c090d28b41ed6c6767d5a296fb87cc5850d5d
    snmp-server community 0b0a9cf540c2c0833a4dc955c588adb92a78c2f61779b4c0
    arm
     wide-bands 5ghz
     80mhz-support
     min-tx-power 127
     max-tx-power 127
     band-steering-mode disable
     air-time-fairness-mode default-access
     client-aware
     scanning
     client-match
    rf dot11g-radio-profile
     interference-immunity 3
    rf dot11a-radio-profile
    internal-domains
     domain-name kcc.com
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    vpn primary <controller public ip>
    vpn monitor-pkt-send-freq 10
    mgmt-user mgmtuser
     xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    wlan access-rule default_wired_port_profile
     index 1
     rule any any match any any any permit
    wlan access-rule wired-instant
     index 2
     rule 192.168.1.70 255.255.255.255 match tcp 80 80 permit
     rule 192.168.1.70 255.255.255.255 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule testing
     index 3
    wlan ssid-profile testing
     enable
     index 1
     type employee
     essid testing
     opmode wpa2-aes
     max-authentication-failures 0
     vlan 100
     auth-server radius1
     auth-server radius2
     rf-band all
     captive-portal disable
     hide-ssid
     dtim-period 1
     inactivity-timeout 1000
     broadcast-filter none
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    auth-survivability cache-time-out 24
    mgmt-auth-server mgmt-server1
    mgmt-auth-server mgmt-server2
    mgmt-auth-server-local-backup
    wlan auth-server mgmt-server1
     ip 10.1.1.1
     port 1812
     acctport 1813
     key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    wlan auth-server mgmt-server2
     ip 10.1.1.2
     port 1812
     acctport 1813
     key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    wlan auth-server radius1
     ip 10.1.1.3
     port 1812
     acctport 1813
    wlan auth-server radius2
     ip 10.1.1.4
     port 1812
     acctport 1813
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
     wireless-containment none
    ip dhcp cl2
     server-type Centralized,L2
     server-vlan 100
    alg
     sccp-disable
     ua-disable
     vocera-disable
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    enet2-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
  • 6.  RE: Managing IAP-VPN AP's from Airwave
    Posted Mar 25, 2014 07:27 AM
    after checking IAP running-config, IAP team think this scenario should work.
    We suggest upgrading IAP to lastest build and get tech-support if still not work.
