Cloud Managed Networks
last person joined: 10 hours ago
Manual cluster for CoA onguard
  • 1.  Manual cluster for CoA onguard
    Posted Aug 09, 2024 11:35 AM
    Hello i was wondering if you really need to configure the manual cluster for the coa to work ? you know to terminate the session and what do you need for onguard to work
    If the answer is yes do i just configure the virtual IPs, the vlan vrrp and the vrrp id and the passphrase and that's it?
    What about the virtual ips which is different in each controller what fw permissions they need? it just that i don't understand how it works
    If anyone can tell me please
    Carlos
  • 2.  RE: Manual cluster for CoA onguard
    Posted 29 days ago
    Carlos, did you see this page already on how CoA in clusters works? I personally have not yet configured CoA with manual clusters, so not sure if you get all the information from there..
  • 3.  RE: Manual cluster for CoA onguard
    Posted 29 days ago
    thanks for answering me!
    as far i understand in the automatic cluster there is no coa for the onguard
    that i need the manual cluster
    if this true or false?
  • 4.  RE: Manual cluster for CoA onguard
    Posted 29 days ago
    i mean im just thinking on configuring the manual cluster just because of the CoA.  If CoA works with automatic cluster will just go with automatic cluster
    let me know
  • 5.  RE: Manual cluster for CoA onguard
    Posted 28 days ago
    Hi.
    First leave cluster on Auto and create the cluster. Then when cluster is formed, change it to manual and enable CoA. This is one way of doing it as it was used in Aruba AOS10 workshops.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
