3rd try for an attachment didn't work. Trying copy paste in body:
APBoot 1.4.0.3 (build 37726)
Built: 2013-03-21 at 20:13:41
Model: AP-10x
CPU: AR7161 revision: A2
Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
DRAM: . 128 MB
POST1: mem 0 mem 1 mem 2 mem 3 passed
Copy: .... done
Flash: 16 MB
PCI: scanning bus 0 ...
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
Net: eth0
Radio: ar922x#0, ar922x#1
Hit <Enter> to stop autoboot: 2 1 0
Booting OS partition 0
Checking image @ 0xbf100000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
ELF file is 32 bit
Loading .text @ 0x80e00000 (6299544 bytes)
Loading .data @ 0x81401fa0 (32 bytes)
Clearing .bss @ 0x81401fc0 (16 bytes)
## Starting application at 0x80e00000 ...
Uncompressing............................................................
þ
Aruba Networks
ArubaOS Version 6.2.1.0-3.4.0.3 (build 40346 / label #40346)
Built by p4build@cyprus on 2013-10-11 at 19:10:16 PDT (gcc version 4.3.3)
CPU Rev: aa
71x CPU
Flash variant: default
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 120576k/131072k available (1687k kernel code, 10400k reserved, 625k data, 5484k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=27214848
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ................................................................................................................................................................................................................................................................................................................................................................................................................................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Talisker RSSI LED initialization
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
.<6>lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Domain Name: arubanetworks.com
No panic info available
Testing TPM... Passed
ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count 400
AG7100: Max rx descriptor count 252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: 24:de:c6:cd:ec:44
ATHRF1: Port 0, Neg Success
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
ag7100_ring_alloc Allocated 4800 at 0x8086a000
ag7100_ring_alloc Allocated 3024 at 0x87e89000
AG7100: cfg1 0xf cfg2 0x7014
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
AG7100: unit 0: phy not up carrier 1
Writing 4
ADDRCONF(NETDEV_UP): bond0: link is not ready
wifi uplink not present...
do ethtool autoneg on for bond0
Ethernet uplink not active yet
Ethernet uplink active. Becoming Mesh Portal
AP xml model 39, num_radios 2 (jiffies 17280)
init_asap_mod: installation:0
radio 0: band 1 ant 0 max_ssid 8
radio 1: band 0 ant 0 max_ssid 8
election init: rand=10 HZ=500
setting bond0 as bridge child
setting gre0 as split child
notify asap_mod 3g no present...
Starting watchdog process...
Getting an IP address...
Dec 31 16:00:34 udhcpc[836]: udhcpc (v0.9.9-pre) started Dec 31 16:00:34 udhcpc[836]: send_discover: pkt AG7100: unit 0 phy is up...num 0, secs 0 RGMii 100Mbps full duplex
Dec 31 16:00:34 AG7100: pll reg 0x18050010: 0x1099 udhcpc[836]: SenAG7100: cfg_1: 0x1ff0000
ding discover...AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0x7ffef
AG7100: done cfg2 0x7115 ifctl 0x10000 miictrl 0x12
ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
Dec 31 16:00:36 udhcpc[836]: send_discover: pkt num 1, secs 2 Dec 31 16:00:36 udhcpc[836]: Sending discover... Dec 31 16:00:38 udhcpc[836]: send_discover: pkt num 2, secs 4 Dec 31 16:00:38 udhcpc[836]: Sending discover... Dec 31 16:00:40 udhcpc[836]: No lease, forking to background. Dec 31 16:01:00 udhcpc[932]: send_discover: pkt num 0, secs 26 Dec 31 16:01:00 udhcpc[932]: Sending discover... Dec 31 16:01:02 udhcpc[932]: send_discover: pkt num 1, secs 28 Dec 31 16:01:02 udhcpc[932]: Sending discover... Dec 31 16:01:04 udhcpc[932]: send_discover: pkt num 2, secs 30 Dec 31 16:01:04 udhcpc[932]: Sending discover... Dec 31 16:01:26 udhcpc[932]: send_discover: pkt num 0, secs 52 Dec 31 16:01:26 udhcpc[932]: Sending discover... Dec 31 16:01:28 udhcpc[932]: send_discover: pkt num 1, secs 54 Dec 31 16:01:28 udhcpc[932]: Sending discover... Dec 31 16:01:30 udhcpc[932]: send_discover: pkt num 2, secs 56 Dec 31 16:01:30 udhcpc[932]: Sending discover... Dec 31 16:01:52 udhcpc[932]: send_discover: pkt num 0, secs 78 Dec 31 16:01:52 udhcpc[932]: Sending discover... Dec 31 16:01:54 udhcpc[932]: send_discover: pkt num 1, secs 80 Dec 31 16:01:54 udhcpc[932]: Sending discover... Dec 31 16:01:56 udhcpc[932]: send_discover: pkt num 2, secs 82 Dec 31 16:01:56 udhcpc[932]: Sending discover... Picked up default IP a9fe2188, rand 2188
Default IP is ready
Dec 31 16:02:18 udhcpc[932]: send_discover: pkt num 0, secs 104 Dec 31 16:02:18 udhcpc[932]: Sending discover... Dec 31 16:02:20 udhcpc[932]: send_discover: pkt num 1, secs 106 Dec 31 16:02:20 udhcpc[932]: Sending discover... Dec 31 16:02:22 udhcpc[932]: send_discover: pkt num 2, secs 108 Dec 31 16:02:22 udhcpc[932]: Sending discover... Dec 31 16:02:44 udhcpc[932]: send_discover: pkt num 0, secs 130 Dec 31 16:02:44 udhcpc[932]: Sending discover... Dec 31 16:02:46 udhcpc[932]: send_discover: pkt num 1, secs 132 Dec 31 16:02:46 udhcpc[932]: Sending discover... Dec 31 16:02:48 udhcpc[932]: send_discover: pkt num 2, secs 134 Dec 31 16:02:48 udhcpc[932]: Sending discover... DHCP timed out.
Installing default ip.
Default IP comes up.
ip_time_handler: Got ip and packets on bond0 Started master election 521-0
DHCP timed out.
DHCP got ip address.
169.254.33.136 255.255.0.0
Compressing all files in the /etc/httpd directory...
Done.
Starting Webserver
bind: Transport endpoint is not connected
NTP Server not saved in flash... using default
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_rate_atheros: Aruba Networks Rate Control Algorithm
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_spectrum: Version 2.0.0
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_pci: 0.9.4.5 (Atheros/multi-bss)
wifi0: Base BSSID 24:de:c6:5e:c4:48, 8 available BSSID(s)
bond0 address=24:de:c6:cd:ec:44
br0 address=24:de:c6:cd:ec:44
wifi0: AP type AP-105, radio 0, max_bssids 8
wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
wifi1: Base BSSID 24:de:c6:5e:c4:40, 8 available BSSID(s)
wifi1: AP type AP-105, radio 1, max_bssids 8
wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
ath_ahb: 0.9.4.5 (Atheros/multi-bss)
Starting FIPS KAT ... Completed FIPS KAT
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
Launching IAP CLI...
process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
i am master now
(00:03:29) !!! Init ---> Master
asap_send_elected_master: sent successfully
User: vap aruba000 vlan is 0. fwd-mode:0 mesh
admin
Password:
24:de:c6:cd:ec:44# sh run
