Hey guys, i am working for a high school in Illinois and have this scenario.
They had an older 3400 controller running 50 or so APS, and have since purchased a new 7210 and an additional 90 aps for deployment. They wanted new SSID/underlying networks for this upgrade. So here is how things stand now with the 7210 and 3400.
Aruba7210-US
6.2.1.5
Master, 140 active AP's
10.1.0.5
144 AP
144 PEF
144 RFProtect
Newer config with new SSID/Networks
Aruba3400-US
6.2.1.5
running as master, 0 AP's
10.1.0.4
56 AP
64 PEF
RFProtect Disabled
Older config with oldunsed SSID/Old Networks
so all aps have been migrated to new 7200 and SSID are good to go.
Now i have been asked about what redundancy we can get using the 7210 and the 3400 in the case of a single controller failover.
I explained that due to AP limits, the most active AP's we could expect to have up if hte 7200 were to fail hard would be 56. They are ok with that.
My thought was to do this.
7210 Master (All aps connected here)
* create a subgroup of AP's called Failover
** configure LMS ip for this group to initially attach to 7210 and failover to 3400)
3400 Local
* no active AP's unless failure of 7210 master
However after reading the guide a bit closer i am guessing i have some license issues due to the fact that the old 3400 controller has 0 RFProtect licences.
Does this setup make sense? any better choices?
If i am goint to make a controller that has a config on it a local, should i wipe it first?
thanks,
chris
#7210#3400
