Wired Intelligent Edge
Max Frame Size and IP-MTU in AOS/AOS-CX with a MacSec interface in use over a ISP/L2tunnel
Jump to Best Answer
  • 1.  Max Frame Size and IP-MTU in AOS/AOS-CX with a MacSec interface in use over a ISP/L2tunnel
    Posted 23 days ago
    ISP/mpls networks, MTU limitation vs. AOS/CX and MACSec
    Based on the ISP requirement/limitation they can only handle a Max Frame Size: 9192;
    Inside the mpls network.
    sh jumbos (AOS)
    Configured :  Max Frame Size :  9216      IP-MTU :  9198
    In Use     :      Max Frame Size :  9216      IP-MTU :  9198
    The CX states on a Physical interface:
    SW(config-if)# mtu
    • BYTES The MTU value in bytes in the range <46-9198> (Default: 1500)
    The CX states on a SVI:
    SW(config-if-vlan)# ip mtu
    • <68-9198> The IP payload MTU value in bytes (Default: 1500)
     What should the Max Frame Size/IP-MTU be set to on the SVI and or Physical,
    for all MacSec frames to be traversed, understanding there is an overhead for the MacSec.
  • 2.  RE: Max Frame Size and IP-MTU in AOS/AOS-CX with a MacSec interface in use over a ISP/L2tunnel
    Posted 22 days ago
    MacSec adds a 32byte overhead to the packets. Based on the mpls network MTU limitation , MTU size can be set in AOS-CX switches i.e 9192-32
    Shobana
    Aruba
  • 3.  RE: Max Frame Size and IP-MTU in AOS/AOS-CX with a MacSec interface in use over a ISP/L2tunnel
    Posted 22 days ago
  • 4.  RE: Max Frame Size and IP-MTU in AOS/AOS-CX with a MacSec interface in use over a ISP/L2tunnel
    Posted 22 days ago
    However is it necessary to decrease the OS,(2930F 's) Max Frame Size of 9216 equally ?,
    Alternatively, will this do the trick on a OS switch:
    • Configured :
      • Max Frame Size : 9216      IP-MTU :  9160
    • And OS-CX:
      • MTU & IP MTU: 9160
