SD-WAN
Max user authenticaiton per port on 9000 series Branch Gateway
  • 1.  Max user authenticaiton per port on 9000 series Branch Gateway
    Posted Jul 21, 2020 08:26 AM
    Hi...I plan for a setup where there will be 9004 BGW on which MPLS and Internet will be terminated..below that there will be a 48 port layer 2 switch (non-aruba) on which users and few IOT devices are connected...Requirement is that all the users and devices should be assigned role's on BGW (with CPPM in place)...Since all the user/IOT authentication and role assignment will be done on BGW, coming from a single uplink from the switch, what is the maximum user auth 9000 series BGW can handle on a single port?
  • 2.  RE: Max user authenticaiton per port on 9000 series Branch Gateway
    Posted Aug 28, 2020 02:39 AM
    here is the link to the datasheet
    https://www.arubanetworks.com/assets/ds/DS_SD-WAN.pdf
    the max auth per port is not mentioned but you can enable 2x ports for LACP if you are worried about the LAN side.
    Also note 9004s can handle 64K of active firewall sessions
