  • 1.  Maximize signal coverage - Aruba OS8
    Posted Jun 14, 2020 04:08 AM
    I have AP-515 connected to 7205 controller running Aruba OS 8.6.4.0.
    The customer need maximum coverage and I have already set the max EIRP (attached screenshot) and still the customer is comparing it with a standalone Dlink AP which has more coverage than this. Is there any other parameters that I can change to make the AP cover the maximum area?
  • 2.  RE: Maximize signal coverage - Aruba OS8
    Posted Jun 14, 2020 06:22 AM
    How is the Aruba AP mounted?  The dlink AP and the Aruba AP have different coverage patterns.
  • 3.  RE: Maximize signal coverage - Aruba OS8
    Posted Jun 14, 2020 06:28 AM
    Dlink on table top and AP-515 on the ceiling. But the customer made one more test by connecting a AP-515 to an external power supply and connecting to a router with DHCP and he configured it with an SSID. He found out that this Aruba AP is giving more coverage than that of the APs connected to the controller. Any idea why?
    Ajin.
  • 4.  RE: Maximize signal coverage - Aruba OS8
    Posted Jun 14, 2020 07:15 AM
    Aruba APs have a downtilt integrated antenna, so the coverage pattern is different from that of a Dlink.  They should not be compared because they are designed for different purposes.  The further you get from an access point, performance decreases, so greater coverage does not equal better performance.
    I cannot answer your second question due to a lack of details.
  • 5.  RE: Maximize signal coverage - Aruba OS8
    Posted Jun 14, 2020 07:20 AM
    Thank you. Just to confirm, is there any other parameter other than the EIRP which can be tweaked for a better coverage?.
  • 6.  RE: Maximize signal coverage - Aruba OS8
    Posted Jun 14, 2020 10:21 AM
    There is no other parameter that would have an affect on coverage.
