  • 1.  Maximum guest users in 9240 local database
    Posted 10 days ago
    Hello all,
    i am desigening a simple wifi network with simple guest access, I am thinking to use the mobility gateway without MM and use the internal captive portal and internal guest provisioning page for create users in the local db, how many guest accounts I can create in the local db?   there is possibility to create about 1000 guest accounts in one time and   to br valid 24 hours from the first access and it delete automatically?
    ACMP ACSP ACCP ACEP ACDP
  • 2.  RE: Maximum guest users in 9240 local database
    Posted 10 days ago
    Edited by shpat 10 days ago
    As i am aware  and if i am not mistaken, the Aruba Mobility Gateways have a default limit of 2,048 guest accounts in their internal database. This means you can create up to 2,048 guest users using the internal guest provisioning page. If your requirement is 1,000 guest accounts, it should be fully supported. However, the number of guest accounts you can create depends on the hardware model and software version.
    As for the 24h activation, you can try the following cli:
    (host) [mynode] local-userdb add username guest1 password yorpassword expiry 24h
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
