Comware
Maximum IRF distance between HPE OfficeConnect 1950 Switch Series
  • 1.  Maximum IRF distance between HPE OfficeConnect 1950 Switch Series
    Posted Mar 19, 2018 07:18 AM
    Hello ,
    I need to stack 2 office connect 1950. They will be linked by CAT6A cable. They will be about 40 meters apart. ( one in each datacenter). Is this possible?
  • 2.  RE: Maximum IRF distance between HPE OfficeConnect 1950 Switch Series
    Posted Mar 19, 2018 06:47 PM
    IMHO 40 meters with certified Cat. 6A cabling shouldn't be problematic at all WRT interconnecting HPE OfficeConnect 1950's XGE ports to deploy an IRF stack where members are located in different rooms/sites (certified Cat. 6A should let you to cover - at maximum - 100 meters using 10GBASE-T, that threshold falls to 55 meters if Cat. 6 certified cabling is used instead of Cat. 6A).
