Maximum Number of Concurrent Management Users
  • 1.  Maximum Number of Concurrent Management Users
    Posted Dec 07, 2012 03:26 AM
    Dear Friends,
    How many concurrent users can access the controller via GUI by using single user name and password.
    let suppose we have only one management with username: admin and password: admin123. how many users can connect using this username and password at the same time.
  • 2.  RE: Maximum Number of Concurrent Management Users
    Posted Dec 07, 2012 08:49 AM
    It might depend on the type of controller you have but you can determine by executing the following command from your controller :
    This is the output from an M3 controller and the default is 25 concurrent web sessions
    (aruba-controller) #show web-server
    Web Server Configuration
    Parameter Value
    Cipher Suite Strength high
    SSL/TLS Protocol Config sslv3 tlsv1
    Switch Certificate default
    Captive Portal Certificate default
    Management user's WebUI access method username/password
    User session timeout <30-3600> (seconds) 900
    Maximum supported concurrent clients <25-400> 25
    But for the CLI/SSH session the maximum I believe it is 5.
    Hope this helps
    If you find the post helpful please Kudo the post
