Hfffoman, same problem to me. But when I try to get access to the set up menu thru 192.168.1.1.. the menu is missing. It´s no possible to re-configure the router again.
I can see that the router's IP is 192.168.2.1.(ipconfig command). Using this IP by the browser it shows a Recovering page from where I can update the firmware again or boot the router.
The net is working. All PCs connectad to the router by wire are working good. IPs assigned by the router are 192.168.2.100, 192.168.2.101 ... and so on. (The LAN is using the old name!!! so, I see that the full reset to factory default is not completed)
I've re-booted, firmware updated, connected and disconnected several times... but nothing happened!!
Maybe I need to do it a dozen times.
Any other suggestion?
Best Regards
