  • 1.  Meraki DHCP Subnet Options
    Posted Apr 13, 2021 12:50 PM
    Has anyone deployed aruba (controller based) aps using DHCP Scope options on a Meraki Switch.  Option 43 and Option 60 formatting needed.  Thanks.
    DeWayne Treff
  • 2.  RE: Meraki DHCP Subnet Options
    Posted Apr 14, 2021 03:59 AM
    Not sure if Meraki switches support Options 43 + 60 but the below covers Windows, Linux and you can extract the values from here.
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/arubaos-solutions/dhcp-option43/dhcp-vend-spec-opti.htm?Highlight=dhcp%20options
    Craig Syme
  • 3.  RE: Meraki DHCP Subnet Options
    Posted Apr 14, 2021 09:13 AM
    Actually I made this way harder than it was.  Attached is a copy of how it should be configured.   Wireshark for the win.
    DeWayne Treff
