Location Services
  • 1.  Meridian error "Could not load directions"
    Posted Nov 16, 2017 09:31 AM
    I am testing Meridian with Beacons and AppViewer. But routing works only in some areas and even not every time.
    In most cases when I choose a point of interest and press the start button to navigate there a message appears:
    How can I fix that?
    Routing paths are created in the editor and Bludot is present on the map.
    #LocationServices
    #Meridian
    #ALE
  • 2.  RE: Meridian error "Could not load directions"
    Posted Dec 07, 2017 09:25 AM
    Hi iurii,
    Are you using the latest appviewer and beacons app?
    What type of device are you using?
    This error can happen if you do not have a proper internet connection, if the app can not measure your position in time, if the routes are too far away from the Poi.
    Did you set the control points up?
  • 3.  RE: Meridian error "Could not load directions"
    Posted Dec 07, 2017 09:51 AM
    Make sure to enable bluetooth and location service on mobile device.
    Pavan
