Chris,
Please double-check that you have set the Control points on all of your maps. To do so, go to maps, press the 'Edit' (pencil) for each map, and set the control points:
I know it sounds strange to link delays to not setting the control points, but I have seen it happen a few times.
As a guidance always set the control points first thing when you start doing work on a map.
Herman
