  • 1.  Mesh AP configuration
    Posted Jul 29, 2019 03:48 AM
    Hi, I am trying to deploy a Mesh network using Aruba 365s.  I have been able to get the Mesh to work using a mesh profile assigned to an AP-group.
    I have an AP that requires slightly different configuration than the majority of the Mesh APs.  I am using bridge mode in the wried-ap-profile with TRUNK set for the AP-group, this single AP needs to use Access port instead.
    The AP is assigned to the AP-group and works using the groups configuration.  I thought I could override the AP-group configuration by assigning a different wired-ap profile directly to the AP but it doesn't appear to work, it just uses the AP-group mesh configuration.
    Does anyone have any experience of this? Is this the correct method or do I have to assigne all Mesh configuration profiles to the AP directly?
    Regards
    Dale Shaw
    Attachment(s)
    txt
    Mesh AP config.txt   6 KB 1 version
  • 2.  RE: Mesh AP configuration
    Posted Jul 29, 2019 08:11 AM
    You can either create a separate group for the mesh point and create the config there, or you can apply at the CLI as an ap-specific command (we don't have ap-specific commands supported in the GUI yet). Just verify that you've applied the AP-specific command and that the config works on the bench before installation.
  • 3.  RE: Mesh AP configuration
    Posted Jul 29, 2019 10:37 AM
    Thank you for your advice Jerrod.
    After further investigation I have identified that the AP specific configuration was working.
    Spanning tree on the switchport was disabling the port becasue it was recieving BPDUs identified as a trunk port, even though it is configured as an access port on the wired-ap-profile.
    Jul 29 10:08:26.753: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk GigabitEthernet0/1 VLAN56.
    Jul 29 10:08:26.753: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking GigabitEthernet0/1 on VLAN0056. Inconsistent port type.
    I disabled spanning tree on the switch and it worked.  I'm not sure why this is or if it is supposed to behave like this.
    Regards
    Dale Shaw
  • 4.  RE: Mesh AP configuration
    Posted Jul 29, 2019 11:59 AM
    Mesh is carrying all switch traffic, if the switches trigger on BPDU, you can disable the remote switch from sending any BPDUs or disable BPDUguard.
