Become a Member
For Controller Capacity , if it supports 1024 campus AP ( Controller 6000 with 1 M3 Module )
RAP is double ( 2048 )
What about Mesh AP ?
2048
If you look on the licensing tab, it will tell you the limits for the platform.
Thx
is ther command from CLI to check that ?
The CLI will only show you active license limits, not platform.
what Path from GUI ?
show license limits
i understood from previous post that i will not be able to get it from CLI
so i was asking about PATH from GUI
From the GUI, You can see from Configuration --> Controller --> Licenses
