  • 1.  Mesh link on DFS channels
    Posted May 27, 2022 12:37 PM
    We have a mesh link installed between a pair of Aruba AP-570 series access points.   The link periodically has latency and data loss issues.  Looking at what the access points see as interference I there is nothing using some of the DFS channels, such as channel 52.   I was looking to see what people thought about using one of the DFS channels for a mesh link.
    Please let me know what you think.
    Thank you
    Bruce Entwistle
  • 2.  RE: Mesh link on DFS channels
    Posted Jun 07, 2022 09:57 AM
    With the mesh link being on the same channel at both ends, you risk that when a DFS event is seen at either end, the link will go down.
    For that reason, if you can avoid DFS channels for mesh, I would avoid it. Note that depending on your region / regulatory domain, there may be none/limited non-DFS channels for outdoor use.
