I have set up an mesh (forward mode: bridge) between two sites.
I want all vlans to pass in the mesh.
The mesh is configured on a controller. Behind the Mesh point is a switch and a client access point which is also connected to the same controller.
The mesh link is stable (RSSI 22) but data flow is not working as it should.
I am unable to get an dhcp ip on the native vlan of the mesh point.
I tried to put the cap on another vlan and it's getting an ip but get's status 2D after provisioning.
Controller logs says "Rebooting: Unable to set up IPSec Tunnel, Error:RC_ERROR_IKEV2_TIMEOUT"
Might the problem be when it passes throgh the controller?
Is there a way to configure the mesh portal not to use a tunnel to the controller?
