I agree with Arne, dont think ESX or EVE is the issue.
I use ESXi 6.7U3 with latest AOS_CX simulator 10.13.0005.
Original Message:
Sent: Jan 09, 2024 08:49 AM
Subject: mgmt int on newer versions of simulator don't work
unfortunately not exactly same environment, I have only ESXi.
Mladen
Original Message:
Sent: Jan 09, 2024 06:35 AM
Just tested on VMWare workstation on my laptop:
With bridged interface "Replicate physical nettwork connection state" must be checked:
Vmware workstation 17.0.0
Windows 11
Arne Opdal
Original Message:
Sent: Jan 09, 2024 06:08 AM
VM deployment is relatively simple, it is like this for both versions of switches
network adapter 1 is for mgmt int., as told in the educational video.
BR,
Mladen
Original Message:
Sent: Jan 09, 2024 04:54 AM
I don't have this problem on EVE-NG, so I don't think it's the simulator. Just check your interfaces and connections to verfy you have it right.
Arne Opdal
Original Message:
Sent: Jan 08, 2024 09:44 AM
on ESXi 7.0 hipervisor
But on all newer versions
VM settings are the same in both cases
Is this behavior bug or feature :) ?
BR,
Mladen
