SD-WAN
  • 1.  Microbranch and hub cluster config?
    Posted Nov 20, 2024 06:03 AM
    If I want to terminate microbranch traffic on a SD-Branch hub running AOS10, do I need to configure the cluster in manual mode and enable VPN termination? Or is that only mandatory if I am running IAP-VPN? The documentation is very unclear regarding Microbranch and hub cluster config.
  • 2.  RE: Microbranch and hub cluster config?
    Posted Nov 20, 2024 05:39 PM
    you dont need manual mode. tunnel and route orchestrator will take care of that with microbranch AP just like branch gateways.
  • 3.  RE: Microbranch and hub cluster config?
    Posted Nov 21, 2024 04:46 AM
    Thank you, someone needs to change info in the HPE press book Aruba Certified Professional Campus Access. The screenshot is from page 220.
  • 4.  RE: Microbranch and hub cluster config?
    Posted Nov 21, 2024 05:20 AM
    We commented internally for modification. Thank you
    Daniel Ruiz
    If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
    Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
