thats great, did you use the first method of just defining your corp domain?
Original Message:
Sent: Oct 23, 2024 02:59 AM
Subject: Microbranch, split dns for CL2?
We tested and it works :)
Original Message:
Sent: Oct 22, 2024 11:47 PM
yes I think it is supported by default, try to configure your corp domain and see.
if that does not work then try the other option for redirect DNS.
Original Message:
Sent: Oct 21, 2024 08:45 AM
Is split DNS supported for a Microbranch CL2 solution? I guess not because the AP is not the default gateway for the client but I can´t find any confirmation in the documentation. With split DNS I mean that corporate domains are redirected to the DNS server in the datacenter and for Internet traffic the clients uses the microbranch AP´s public DNS.
Configuring AP
Validated Solution Guide | remove preview |
