  • 1.  Microsoft Intune Onboard Enrollment Extension
    Posted Sep 30, 2024 05:55 PM
    I would like to install ClearPass Onboard as SCEP server for enroll certificates with Intune. I install the Intune SCEP 1.4.2 extension. I follow the technote Microsoft Intune Onboard Enrollment Extension which is old and not well documented. I don't get it work and i can't find any youtube tutorial  or other documentation.
    It seems like that the Microsoft Graph API is changed over time.
    When sync my Intune Managed Device it failed with the ClearPass URL. Note: ClearPass is accesible through 443tcp over internet and has https certificate.
    Error logging managed device:
    Some help should be awesome!
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 2.  RE: Microsoft Intune Onboard Enrollment Extension
    Posted Oct 02, 2024 09:54 AM
    Hi mkk,
    Have you checked the ClearPass Guest Application logs ?  Do you see any event or error at the same timestamp there?
    You might want to work with TAC on this issue.
  • 3.  RE: Microsoft Intune Onboard Enrollment Extension
    Posted Oct 17, 2024 06:11 AM
    The was no logging vissible even nothing in debug mode.
    I resolved the issue.
    The issue was that the scep profile in intune need the intermediate certificate and not the root certificate for windows 10 devices. This was wrong in de aruba technote documentation and will be changed.
