Far as i known you can backup and restore from a virtual to a hardware appliance.
Licenses on your virtual mobility conductor are bound the the system passphrase and must be migrated through the asp.arubanetworks.com portal (or contact support) to move to the new hardware.
On your Mobility Controller the master-ip must be pointed to the mobility conductor. This IP is used by the mobility controller to initiate a IPSEC tunnel to the mobility conductor, after the IPSEC is established the Mobility Conductor will push the managed device configuration to the mobility controller. Be sure you new Conductor have the same managed device configuration, it will override your current mobility controller configuration when something is different ;).
For your migration you will probably like to use a new IP on your mobility conductor, so you can first move one controller to test your new setup.
When not very familiar with the process i would advice you to work with your local Aruba Partner for a smooth migration.
Marcel Koedijk | MVP Guru 2021 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
Original Message:
Sent: Jan 05, 2022 12:15 PM
Subject: Migrate Mobility Conductor from VM to Hardware
I have an engagement coming up to migrate a 2 node Mobility Conductor cluster from VM to hardware appliances. My original thought was to migrate the backup MM first but then I realized you can't have a VM and hardware in the same cluster (I think - I know that's true for controllers, trying to find the doc for MMs now). I will still do it that way, but break the dependency first. My question is what kind of gotchas might I get from the controller side? When you initially set up a controller to point to an MM, it asks if the MM is VM or HW. That leads me to believe I may need to make a change on the controllers when I migrate. For a point of reference, the new MM instance will have all of the old IP addresses, VIP, etc as the old
So to put it in a nutshell, I have 2 main questions
1) What is the best practice to migrate this (restore new HW from flashbackup of old VM, create new instance and copy-and-past and then change the IPs, something else)
2) Is there anything I need to do on the controller side if the MM it is pointing to changes from VM to HW?
Jeff Johnston
Jeffrey Johnston
