Migration and Backout processes of Campus APs (half working)
This thread has been viewed 63 times
  • 1.  Migration and Backout processes of Campus APs (half working)
    Posted Mar 15, 2024 04:43 PM
    I am trying to test the migration of a Campus environment to Aruba Central and potential backout in case I run into errors.
    The process to Aruba Central is straightforward with the documentation I could find. The backout process unfortunately does not go as smoothly.
    Unless I use brute force aka a paperclip and the reset button I cannot get my APs to connect to my controller again.
    My setup:
    VMC with 8.10.0.10_89128
    345 AP running 8.10.0.10_89128
    DHCP server options 6,42,43,60 (all to local IP addresses)
    Converting the access-points to Aruba Central was straight forward and consisted of:
    Step 1: Provision Access-Point in Greenlake (assign service manager and subscription tier)
    Step 2: Open Firewall ports for NTP/DNS/HTTPS or define DHCP options 6 (DNS), 42 (NTP) and just open HTTPS
    Step 3: Issue the command for group or ap conversion (ap convert add ap-group|ap-name <something>)
    Step 4: Issue the command to test Aruba Central readiness (ap convert pre-validate specific-aps) << NTP DNS error or NTP Unreachable when either are blocked by firewall or AP have no provision rule(Activate) when Aruba Central isn't ready.
    Step 5: Issue the AP convert command:"ap convert active all-aps server ftp username ftp-user 10.254.254.3 ArubaOS_Draco_10.4.1.0_88715"
    Step 6: Keep validating with "show ap convert-status"
    Step 7: Validate in Aruba Central, so far so good, al seems to be ok, I can see and reach the device in central
    Now the opposite route, what if I want to revert back to the controller-based solution.
    These steps I defined:
    Step 1: Downgrade OS to from Aruba Central back to 8.10.0.10_89128
    Step 2: Remove service manager and subscription tier from AP
    Step 3: ????
    Out of itself this AP will not connect back to my Virtual Controller, I logged through the console but nothing seems to work. Oddly enough the username and password appeared to have reset with this downgrade to admin/admin. Eventually I issued a factory reset using the paperclip method. This got the AP back online, but isn't really a solution I can issue remote. What step have I overlooked?
    I hope someone can help point me in the right direction.
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 15, 2024 04:52 PM
    You will also have to convert the AP back to a CAP WAP.
    convert-aos-ap cap <controller-address>
    Covered here - in Section "Revert to AOS 8 Firmware Version"
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 16, 2024 09:41 AM
    That was the missing piece, it worked!
  • 4.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 09:45 AM
    New link for posterity: https://www.arubanetworks.com/techdocs/aos/aos10/migrate/aps/cap/#revert-to-aos-8-firmware-version
    Carson Hulcher, ACEX#110
  • 5.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 10:19 AM
    Thank you, I can add as well that I noticed that this method worked for any Access-points I had running in Aruba Central, regardless of the fact that they were previously associated with the controller.
  • 6.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 10:26 AM
    The command is used for converting any AP running IAP or AOS 10 to a campus AP.
    Note, only one of the two images on the AP is converted to the campus AP image, you can end up in a situation where the AP will boot to the non-campus image and the AP doesn't behave as expected.
    Downgrade from AOS 10 to AOS 8 should only be done when absolutely necessary.
  • 7.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 11:54 AM
    Thanks Carson
    This is currently all simulation of course but I want to be sure when performing this in the production network I am not overlooking anything.
    I can see indeed that the backup is still set to AOS10 by issuing the show ap image version output below.
    So in the hypothetical situation that I need to backup a migration to Aruba Central, should I synchronize these two flash drives to prevent unforeseen issues? I don't dare to ask but, how would I do that? I couldn't find a command to do that from the controller.
  • 8.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 12:04 PM
    The controller will only ever upgrade the primary partition, the secondary is left untouched to provide a fallback.  What you'd probably have to do is, while running AOS 10, load a version of IAP to the secondary partition before converting back to CAP.  As long as DHCP discovery is configured properly, even the IAP image will eventually find the controller automatically and convert again.
    Note though, AOS 10 is moving away from having two complete images stored in flash as we move towards a more services based architecture for the AP software.  That change will impact the ability what I've stated here, I just don't know exactly how at this point.
  • 9.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 12:18 PM
    So if I understand correctly, try something like:
    • Connect to the APs while in Aruba Central through console
    • Wipe out flash (?)
    • Copy the image to the backup flash
    • Revert back?
  • 10.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 12:45 PM
    Right now when you load new software on an AP running IAP or AOS 10, the non-default partition is used for the software load then switched over to prior to reboot.
    So the easiest way would be to make sure that the AP is running on an image in the primary partition (might require an "upgrade" to move active from secondary to primary), then upgrade the secondary image without booting to that image (upgrade-image2-no-switch-partition-reboot <url>), and then immediately convert back to CAP.
  • 11.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 12:10 PM
    unsure of your model AP you are using, but I have had success flashing the backup partition on 300 series ap using the ap31x-ap32x backup partition.
    With AOS 8.10.0.10 I was able to also flash 315 AP backup partitions.
    regards,
  • 12.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 12:14 PM
    That particular command only works for those specific models, which is why I don't bother mentioning that as an option.
  • 13.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 12:42 PM
    thanks insightful
  • 14.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 01:19 PM
    Edited by mvanoverbeek Mar 18, 2024 01:19 PM
    Just a thought about the revert process. Would it be an idea to create a temporary AOS8 group on Aruba Central and before reverting AOS10 back to the local controller based version, downgrade to AOS8 from Aruba Central and then issue the conversion from Aruba Central? That way at least I would don't have this descrepancy:
    So full backout process would be:
    Step 1: Move AOS 10 AP to AOS8 group
    Step 2: (When AP is reachable and booted from AOS8): aos-convert-ap cap <a.b.c.d>
    Step 3: Reboot if required
  • 15.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 01:24 PM
    If that method works for you, then sure.
  • 16.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 02:08 PM
    Actually, not quite. When I used this method in Aruba Central and issued the command "show image version" the secondary Flash still had AOS10 running (see below)
    Kitchen# show image version
    Primary Partition                 :1
    Primary Partition Build Time      :2024-02-2 07:45:51 UTC
    Primary Partition Build Version   :8.10.0.10_89128 LSR (Digitally Signed - Production Build)
    Backup Partition                  :0
    Backup Partition Build Time       :2023-12-9 03:59:26 UTC
    Backup Partition Build Version    :10.4.1.0_88715 LSR (Digitally Signed - Production Build)
    AP Images Classes
    Class
    I had to set up a tftp server with the correct image and issue:
    upgrade-image2-no-reboot tftp://10.254.254.2/ArubaInstant_Gemini_8.10.0.10_89128
    This eventually resulted in both images to be back at the correct AOS level
    Backup Partition                  :0
    Backup Partition Build Time       :2024-02-2 07:45:51 UTC
    Backup Partition Build Version    :8.10.0.10_89128 LSR (Digitally Signed - Production Build)
    AP Images Classes
    My problem this time however was that at AOS8 logged in through console (in aruba central):
    convert-aos-ap cap x.x.x.x did not do anything anymore.
    What I did instead now is in Aruba Central Global remove it completely, this resulted in a reboot and the Access-Point showed up again in my controller-based network.
    To summarize the steps for backout:
    Prerequisites: Have an scp/ftp/tftp server ready with correct images, have DHCP enabled in your network with option 43 and 60
    Step 1: Move to AOS8 group
    Step 2: TFTP AOS8 image to backup flash-drive (upgrade-image2-no-reboot tftp://x.y.z.a/ArubaInstant_Gemini_8.10.0.10_89128
    Step 3: Validate image versions with show image version
    Step 4: Move AP to default group (is this step necessary?)
    Step 5: In global mode, delete AP and reboot
  • 17.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 18, 2024 02:48 PM
    I like that method/result, and you should get consistent results as long as the DHCP scope is configured to instruct UAP/IAP APs to automatically convert to controller based.
  • 18.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 19, 2024 01:40 PM
    Not sure what is going on but the procedure I tested yesterday does not work  as flawlessly as today.
    I created a dummy-AOS 8 group, set the firmware compliance but when I migrated two access-points (a 515 and a 345) to this group both did not come back online anymore.
    I tested the 515 at my desk with console and there it got back online however TFTP which worked fine to upgrade the device yesterday refused to work today. The TFTP server provided logs stating connection dropped because peer didn't respond.
    Office515# show upgrade
    swarm upgrade status
    Mac                IP Address    Seed AP  AP Class  Status    Image Info                                              Error Detail
    d0:15:a6:cb:25:a8  10.254.254.7  Yes      Draco     image-ok  tftp://10.254.254.2/ArubaInstant_Draco_8.10.0.10_89128  Retrieve image fail
    Auto reboot           :disable
    Use external URL      :enable
    Conductor wait Time   :2781 secs 0 count
    Switch Partition      :enable
    Upgrade in process    :Yes
    UAP convert process   :No
    Office515# upgrade-image2-no-reboot tftp://10.254.254.2/ArubaInstant_Draco_8.10.0.10_89128
    Eventually I was able to execute the step using ftp. I just find it strange that TFTP worked fine yesterday but not today.
  • 19.  RE: Migration and Backout processes of Campus APs (half working)
    Posted Mar 19, 2024 02:03 PM
    One additions to above, I checked with the serial cable and noticed that initially the 345 was plugged into port 1 of the AP and was unable to retrieve a DHCP lease.
    Logs on port 1
    Hit <Enter> to stop autoboot:  0
    Booting OS partition 1
    Checking image @ 0x2000000
    Copying image from 0x0000000008000000
    Image is signed; verifying checksum... passed
    SHA2 Signature available
    Signer Cert OK
    Policy Cert OK
    RSA signature verified using SHA2.
       Loading fdt from 0x09a88fbc to 0x0007c000
    Uncompressing Kernel Image ...    reserving fdt memory region: addr=0 size=20000
    OK
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 8.10.0.10-8.10.0.10 (build 89128 / label #89128)
    [    0.000000] Built by jenkins@3a84b2c4aede on 2024-02-02 at 07:41:41 UTC (gcc        version 5.3.0 (Buildroot 2016.02) )
    [    8.571780] brcmboard registered
    [    8.603392] broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
    [   10.570683] Enabling all watchdogs
    [   11.257063]
    Starting Kernel SHA1 KAT ...
    [   11.296778] Completed Kernel SHA1 KAT
    [   11.343732] Starting Kernel HMAC-SHA1 KAT ...
    [   11.393819] Starting Kernel DES KAT ...[   11.439731] Completed Kernel DES KAT
    [   11.483517] Starting Kernel AES KAT ...
    [   11.527369] Completed Kernel AES KAT
    [   11.527369]
    [   11.590981] Starting Kernel AESGCM KAT ...
    [   11.693229] Completed Kernel HMAC-SHA1 KAT
    Thu Jan  1 00:00:00 PST 1970
    Populate AP type info
    Domain Name: SetMeUp.arubanetworks.com
    Current OEM Name : Aruba Networks
    Disabling ipv6 for devices by default
    AP-type has_ble_support: ONBOARD.
    IPv6 capability is supported for devices
    No panic info available
    Enabling ble_daemon and ble_relay via nanny
    masterson: Start hotplug
    Backup ENV.
    Loading Broadcom[   16.877437] wlcsm: module license 'Proprietary' taints kernel.
    [   16.954190] Disabling lock debugging due to kernel taint
     drivers and kernel modules...
    [   23.007127] bcmswlpbk0 (Ext switch port: 8) (Logical Port: 8) Virtual link DOWN
    Starting Broadcom Switch daemon (SWMDK)...[   23.130701] isl28022: loading out-of-tree module taints kernel.
    Enabling Broadcom traffic management for eth0 port (TMCTL)...
    Enabling Broadcom traffic management for eth1 port (TMCTL)...
    Enter non-FIPS mode
    Cfg len is 4001
    uap controller less detected
    Mesh disabled
    dual uplink platform just by factory default
    Ethernet port 1 mode: active-standby
    [   23.822571] phy_dev_power_set: port_name = eth0,  phy_addr = 6
    Eth0 has been enslaved in bond0
    Eth1 will be enslaved in bond0 for lacp detection.
    Starting watchdog process...
    Aruba watchdog daemon started [1 thread(s)]
    Loading configuration file of length 4001...
    wifi uplink not present...
    extended ssid config detected...
    Terminal access enabled...
    Valid SSID detected...
    touching file /tmp/ip_mode_0
    do ethtool autoneg on for eth0
    init usb modem ...
    Ethernet uplink bond0  not active yet
    error in reading source file
    Mesh is DISABLED on this device.
    extended[   55.011217] uol_init_driver:435 HW offload not applicable, AP will use cutting through path!
     ssid is activated on the platform ...
    copying bootuplog ...
    allow PAPI
    set device anul0 mtu to 2000
    notify asap_mod 3g no present...
    apdot1x authentication is not enabled
    LLDP not sent yet, DHCP is waiting
    [   60.120182] bcmswlpbk0 (Ext switch port: 8) (Logical Port: 8) Virtual link UP
    [   60.198541] eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link Up at 1000 mbps full duplex
    Starting DHCP
    Eth1 has been removed from bo[   75.586315] phy_dev_power_set: port_name = eth1,  phy_addr = 11
    nd0 after lacp detection
    (none)
    Compressing all files in the /etc/httpd directory...
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    NTP server north-america.pool.ntp.org from configuration.
    Put ntpdate to the nannylist.
    AP rebooted Fri Feb  2 07:47:16 UTC 2024; System cmd at uptime 0D 0H 6M 52S: Current uplink down, no useable uplink
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    Completed SW FIPS KAT test
    USB Modem is not presenUser:
    User:
    User: ble_ready NOT present @init ....
    User: admin
    System uptime is 100 seconds and CLI is not ready yet, please try again later.
    User: [  112.304187] ip_time_handler: Got ip and packets on bond0 Started conductor election 1-0, rand 21
    User: admin
    System uptime is 122 seconds and CLI is not ready yet, please try again later.
    User: [  133.432246] (12:42:32) !!! Init ---> Conductor
    Logs on port0
    When I plugged it into Eth0 it was able to obtain a lease.
    DDR test done successfully
    Loading image 0...
    Validating image 0...
    Uncompressing image 0...
    Booting image 0...
    APBoot 2.4.0.1 (build 63683)
    Built: 2018-02-13 at 13:40:06
    Model: AP-34x
    DRAM:  512 MiB
    NAND:  ECC BCH-8, ONFI, Manuf ID: 0xef, Chip ID: 0xf1 (Winbond W29N01HV), page size: 2048, OOB size: 64, device size: 128 MiB
    PCIE1: link up
    PCIE2: link up
    Power: 802.3af POE
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0, eth1
    Radio: bcm43465#0, bcm43465#1
    Reset: cold
    FIPS:  passed
    Signer Cert OK
    Policy Cert OK
    OK
    [    0.000000]
    [    8.574716] brcmboard registered
    [    8.606313] broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
    [   10.575617] Enabling all watchdogs
    [   11.261617]
    [   11.301394] Completed Kernel SHA1 KAT
    [   11.301476] Starting Kernel HMAC-SHA1 KAT ...
    [   11.301504] Starting Kernel DES KAT ...
    [   11.301504] Completed Kernel DES KAT
    [   11.301533] Starting Kernel AES KAT ...
    [   11.301534] Completed Kernel AES KAT
    [   11.301534]
    [   11.301537] Starting Kernel AESGCM KAT ...
    [   11.301537] Completed Kernel AESGCM KAT
    [   11.303894] Completed Kernel HMAC-SHA1 KAT
    Backup ENV.
    Loading Broadcom[   16.982535] wlcsm: module license 'Proprietary' taints kernel.
    [   17.059260] Disabling lock debugging due to kernel taint
    [   23.112222] bcmswlpbk0 (Ext switch port: 8) (Logical Port: 8) Virtual link DOWN
    Starting Broadcom Switch daemon (SWMDK)...[   23.236274] isl28022: loading out-of-tree module taints kernel.
    Enter non-FIPS mode
    Cfg len is 4001
    Mesh disabled
    [   23.921627] phy_dev_power_set: port_name = eth0,  phy_addr = 6
    init usb modem ...
    [   29.001883] bcmswlpbk0 (Ext switch port: 8) (Logical Port: 8) Virtual link UP
    [   29.080344] eth0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1e) Link Up at 2500 mbps full duplex
    extended[   29.818018] uol_init_driver:435 HW offload not applicable, AP will use cutting through path!
    allow PAPI
    Starting DHCP
    Getting an IP address...
    Jan  1 00:00:25 udhcpc[5478]: udhcpc (v0.9.9-pre) started
    Jan  1 00:00:25 udhcpc[5478]: send_discover: pkt num 0, secs 0
    Jan  1 00:00:25 udhcpc[5478]: Sending discover...
    Jan  1 00:00:26 udhcpc[5478]: send_selecting: pkt num 0, secs 512
    Jan  1 00:00:26 udhcpc[5478]: Sending select for 10.254.254.6...
    Jan  1 00:00:26 udhcpc[5478]: Lease of 10.254.254.6 obtained, lease time 604800
    Jan  1 00:00:26 udhcpc[5478]: DHCP OPT 60 is ArubaAP
    Jan  1 00:00:26 udhcpc[5478]: DHCP OPT 42, len: 4, ip: 10.254.254.1
    [   38.979103] ip_time_handler: Got ip and packets on bond0 Started conductor election 25-0, rand 18
    [   39.653857] (08:00:27) !!! Init ---> Member
    Eth1 has been removed from bo[   59.555240] phy_dev_power_set: port_name = eth1,  phy_addr = 11
    10.254.254.6 255.255.255.0 10.254.254.1
    Loading image 0...
    Booting image 0...
    Model: AP-34x
    DRAM:  512 MiB
    PCIE1: link up
    PCIE2: link up
    Power: 802.3af POE
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0, eth1
    Reset: cold
    FIPS:  passed
    Signer Cert OK
    Policy Cert OK
    OK
    [    0.000000]
    [   11.261617]
    [   11.301534]
    Backup ENV.
    Enter non-FIPS mode
    Cfg len is 4001
    Mesh disabled
    init usb modem ...
    allow PAPI
    Starting DHCP
