Comware
  • 1.  Mini Gbic HP JD493A x Mini Gbic 3Com 3CSFP91
    Posted Feb 28, 2012 12:19 PM
    Hello Dears,
    I need help with mini gbics, i bought a mini-gbic HP JD493A but i received one 3Com 3CSFP91, the question is this produts are same?
    Have a difference technique??
  • 2.  RE: Mini Gbic HP JD493A x Mini Gbic 3Com 3CSFP91
    Posted Feb 28, 2012 12:23 PM
    Don't worry, the 3CSFP91 is the exact same product as JD493A, the first part number is just the original 3Com Part Number and the second the newer HP Part Number.
    Enter either of the numbers into the support & lookup tool and you'll notice they list the same product too:
    http://h17007.www1.hp.com/us/en/support/converter/index.aspx
    Hope that helps :-)
  • 3.  RE: Mini Gbic HP JD493A x Mini Gbic 3Com 3CSFP91
    Posted Mar 18, 2014 07:01 AM
    If both SFP's are the same, why does the 3CSFP91 works fine in a HP procurve 1810 and not in a HP procurve 2530 ?
    Is there a possibility to get my existing 3CSFP91 SPF's to work in our new HP 2530 procurve switches ?
    Regards
    Georges Goebel
