Wired Intelligent Edge
  • 1.  Mirror Port 2930F Switch
    Posted Nov 22, 2018 02:10 PM
    Hi there,
    Does the 2930F switch have the capability to mirror ports?
    I am trying to monitor a port and cannot see any configuration command for it.
    Quick response would be fantastic, much obliged.
    #2930F
  • 2.  RE: Mirror Port 2930F Switch
    Posted Nov 23, 2018 05:33 PM
    Hi
    You can find commands in this manual:
    https://support.hpe.com/hpsc/doc/public/display?docId=a00055700en_us
    page 391
    Regards
    PS: If this helps you, please give some kudos
  • 3.  RE: Mirror Port 2930F Switch
    Posted Dec 10, 2018 01:34 PM
    You have local and remote mirrors in AOS-Switch. Since you're not specifically asking for remote mirrors I'll provide an example of a local mirror. A local mirror copies traffic to a certain destination port on the same switch. Hereby the steps:
    • mirror 1 - 4 port <PORT# EXIT the traffic>
    • Then you go to:
      - interface <PORT/TRUNK>
      monitor all [in|out|both] mirror <SESSION> [no-tag-added]
      This is the most simple version of a mirror. You have more functions to select specific traffic, remote mirror etc.
      Hope this helps you!
      Dobias
