Wired Intelligent Edge
  • 1.  Mirroring Session on Aruba 5406R
    Posted Feb 07, 2025 03:58 PM
    I am sure I am simply missing a step or reading the instructions incorrectly. Here is my issue.
    I have an Aruba 5406r . I want to set up a couple of monitoring sessions.  I understand I can set up 1 - 4 sessions.  I create the first session and assign an exit port.
    I can then run the command "show monitor" and it appears fine. I can then assign an interface and when I run "show monitor 1" I see the Mirror Destination (exit port) and the Monitoring Source. All is good.
    I then add a second session and "show monitor".
    I can see session 1 is active and it has  single source. Session 2 shows inactive and no source. All is as I expect.
    Here is the problem . How do I assign an interface to Session2?
    If I create the new session 2 and then immediately assign an interface, it always is assigned to session 1 and its exit port.  So when I click show monitor, session 1 shows 2 sources and session 2 is still inactive with 0 sources..
    I do not know what command assigns the interface to a specific session. It always defaults to session 1 and I cannot find away to get around this.
    Peter
  • 2.  RE: Mirroring Session on Aruba 5406R
    Posted Feb 07, 2025 04:14 PM
    Hi, have you already read the old post below?
    It could shed some light about the topic (documentation apart).
  • 3.  RE: Mirroring Session on Aruba 5406R
    Posted Feb 07, 2025 05:24 PM
    That was it exactly. Thanks! I was missing the last bit about assigning it to a mirror so by default it was going to 1.
