Network Management
  • 1.  Mismatched VC
    Posted Dec 26, 2019 09:52 AM
    Herllo!
    We are facing some strange issue: we have a VC that from last week do not get the Good status.
    Looking at the mismatched configs, at Instant Config option in Airwave, it only shows me this:
    Mismatches for VC : VC-SECXXI
    Change to VC configuration:
    ui-cert-checksum 0096e965eeea7dac57f4c5fac9a3268e
    The thing is that I already tried to put this option by myself on IAP cli, and it does not exist. There is no ui-cert-chechsum option. How can I get around this?
  • 2.  RE: Mismatched VC
    Posted Dec 30, 2019 04:41 AM
    If you have uploaded certificate in IAP, try upload same in Airwave under Device Setup > Certificate and map certificate under Group>Basic >Aruba Instant section (Airwave group where IAP is added)
  • 3.  RE: Mismatched VC
    Posted Dec 30, 2019 05:19 AM
    Hello!
    Thanks for your reply, but we already did that. Las Friday I managed to solve this forcing AirWave to get the template from the IAP. After trying to do that some times, it finally got Good status.
    I followed this link to do so.
    Thanls
