Yes, protected management frames are mandatory on 6GHz because these are mandatory for WPA3 which is mandatory on WiFi-6E.
Even with thousands of users, with uncontrolled devices, it may be good to find one or a few and do further investigations on those because it may help to develop more generic guidance for the wider user population. If you don't want to invest time in there, and moving back to WPA2 (Except of 6GHz), and that resolves your issue, that's an option as well, but at one point in time you probably have to, and yes or no (most of) the issues have resolved automatically by then.
Aruba Support should be able to assist you in the troubleshooting, but they would need some more detailed and reproducible data on client issues.
Original Message:
Sent: Oct 06, 2023 11:48 AM
Subject: Missed logins with 802.1x SSID and WPA3 AES CCM 128,
Hi, thanks for reply
This is highly volatile, it is extremely difficult to investigating thousands of student pc/mac for any misbehaving driver.
This is a longshot, and varius also between 5Ghz SSIDs and 6GHz, which does it it a wild gueswork :(
And yes you understand correct..
Disabling PMF/MFP, is only an option on 5Ghz, if I remember correct..?
(mandatory on 6Ghz ?)
Steinar
