Hi folks,
I'm currently working with the ClearPass export filters. The Insight log template almost fulfil my needs but I still miss the full Alert message. There is a field CppmAlert.Alerts but it is always empty. I can already retrieve the error code and the corresponding details but it is not the full alert message like the screenshot below :
Is it intended or am I missing something ? I also know that I can retrieve it with the Session template but it doesn't contain other fields I need like the SSID if it is a wireless RADIUS request.
The last option is to use SQL but I want to know if it could be done with the templates before jumping in this rabbit hole.
Thanks in advance !
