  • 1.  Missing settings when managing IAPs in AirWave?
    Posted Apr 03, 2018 09:27 AM
    Greetings!
    Looking to start managing IAPs with AirWave.  I turned on "Enable Instant GUI Config" in the group, and like the familiar interface. However, it seems like some optoins are missing.  For example, when editing an SSID directly on an IAP cluster, under Security there are options for Fast Roaming (OKC, 802.11r, k, v).  Those options appear to be missing under Security when editing an SSID in AirWave.  Are they located somewhere else, or is this a lmitation of AirWave?
    Thanks in advance.
  • 2.  RE: Missing settings when managing IAPs in AirWave?
    Posted Apr 03, 2018 10:17 AM
    Hey, which version of AirWave and InstantOS are you running? This maybe a version issue.
  • 3.  RE: Missing settings when managing IAPs in AirWave?
    Posted Apr 03, 2018 11:31 AM
    Instant OS is 6.5.4.2.
    I had wondered the same thing and upgraded AirWave to 8.2.5.1, but no difference in this regard.
