Missing Syslog messages
  • 1.  Missing Syslog messages
    Posted Sep 13, 2016 09:42 AM
    Hi All,
    We run a hosted Aruba solution for several colleges and we use a Palo Alto firewall with UserID authentication. We send a syslog message to a syslog server that then sorts out which college the user is from and then it forwards the message to the correct UserID agent.
    This has worked fine but we are starting to have some issues with it where the controllers do not send a syslog message when the users logs on.
    Does anyone know if there is a limit to how many syslog messages the controllers can send at any given time? Or how to debug why a certain syslog message is not sent from the controller even if it should?
    Our setup is 7210 as Master/Master standby controllers and 7220 as local controllers. The Master controllers has no access point terminating on them.
    Logging levels
    Facility Level
    arm warnings
    network warnings
    security warnings
    system warnings
    user notifications
    wireless warnings
    Logging configuration
    logging level notifications user process authmgr
    logging level notifications user subcat all
    logging level notifications user subcat captive-portal
    logging level notifications user subcat client-match
    logging level notifications user subcat dot1x
    logging level notifications user subcat mapc
    logging level notifications user subcat pan
    logging level notifications user subcat radius
    logging level notifications user subcat voice
    logging level notifications user subcat vpn
    logging 10.150.111.251 type user severity informational
    logging 10.150.113.51 type user severity informational
