Mix of iAP105 and iAP103-RW
  • 1.  Mix of iAP105 and iAP103-RW
    Posted May 01, 2020 01:05 PM
    can i mix iAP 105 and 103?
    I try to connect the 103 but after reset i can´t Login.
    best
    face
  • 2.  RE: Mix of iAP105 and iAP103-RW
    Posted May 04, 2020 12:47 PM
    If you can get them to run the same version of instant OS code, then it should work.
