  • 1.  Mixing AP-225 and AP-325/AP-335 in buildings
    Posted Jan 10, 2020 10:48 AM
    Happy New Year!
    Any issues with mixing AP-225s and AP-325s within a building? Like on either side of a wall? What about AP-225s and AP-335s? We are trying to backfill coverage or density gaps in established buildings that have AP-22x deployments.
    Thanks!
    Mike
  • 2.  RE: Mixing AP-225 and AP-325/AP-335 in buildings
    Posted Jan 10, 2020 01:08 PM
    From a strategic perspective, you should seek to keep the same AP type in the same roaming domain.  Why?
    - Roaming could, might be different between different AP models, even with the same phy.  (different receive sensitivity and spatial stream capability)
    - The more AP exceptions you make in your infrastructure, the harder it will be to solve zero-day problems.  It will also be harder to replicate zero-day problems if the problem is roaming from one AP type to another
    - If there is a version of code that leaves a single type of AP behind, you will have to physically identify APs that are possibly hidden, to make that transition.
    It would be very easy to say, sure you can just mix and match those APs because they have the same phy type.  If you don't care about the strategic considerations above, I am sure it would be fine.
  • 3.  RE: Mixing AP-225 and AP-325/AP-335 in buildings
    Posted Jan 10, 2020 01:18 PM
    Colin,
    This is spot on..perect! I couldn't agree more. Needed your expert data point to enfore what many of us already feel.
    Thanks again,
    Mike
