Become a Member
Hello the community
I am new in Aruba World .
We have some networks with IAP103 and want to extend them.
Is it possible to mix IAP103 with IAP204 , IAP275 and IAP207 ?
What do I need to pay attention to ?
Thank you .
you will need to ensure that they are all running the same software version, else a cluster won't form.
Thank you Matthew
So maybe , I'll have to update all my "old" IAP103s to the min version of my "new" IAP¨275 and 207.
You think I will be able to have the same software version for all of them ?
No bad surprise like "Min version for new IAPs" > "Max version for old IAPs"
You can check the minimum version per AP in the AP datasheets, and the maximum in the End-of-Life page on the Aruba website.
IAP-103 will run Aruba Instant up to 4.2, the IAP-207 requires 4.3.1, so you can't create a single cluster with IAP-103 and IAP-207.
Check this page for a similar question.
