  • 1.  Mixing wifi6 and wifi6E
    Posted Dec 29, 2023 08:38 AM
    Hi Team,
    My client wants to Mix AP-505 for corridors and AP-635 for lobbies. What is the impact of this?
    Please clarify.
    Shamal
  • 2.  RE: Mixing wifi6 and wifi6E
    Posted Dec 31, 2023 01:23 AM
    there is no issue mixing it since both models are 2x2:2 .
    just be aware that 6Ghz band requires WPA3. Some older clients non-6E, don't operate properly with WPA3
  • 3.  RE: Mixing wifi6 and wifi6E
    Posted Dec 31, 2023 01:55 AM
    Thanks for the reply.
    What do you think of roaming. If a 6GHz client roams to 5GHz AP, it will reconnect right? that removes the seamless roaming?
    Thanks.
    Shamal
  • 4.  RE: Mixing wifi6 and wifi6E
    Posted Dec 31, 2023 05:46 PM
    as long as you are using WPA3 ESSID on 5 GHz and 6GHz bands, you should be fine. But as I mentioned earlier, always test the older clients.
  • 5.  RE: Mixing wifi6 and wifi6E
    Posted Jan 02, 2024 09:45 AM
    From what I've seen of client behavior, if the client ever connects to 5 GHz then the device is unlikely to roam to 6 GHz.  So any installation where you expect people to be moving between islands of 6 GHz coverage will usually result in very little activity within the 6 GHz band.
    Carson Hulcher, ACEX#110
