That will not work. It is possible now. However, you need to use EVPN-VXLAN. This is called EVPN-VXLAN multihoming
Original Message:
Sent: Mar 13, 2025 06:40 AM
Subject: MLAG between two VSX
ok thanks for the reply, yes i have one. But like i read before my scenario is not possible because are two different vsx.
Original Message:
Sent: Mar 13, 2025 06:23 AM
Do you have a diagram?
We only do MC-LAG to members of the same VSX pair.
So lets say, SW1 and SW2 are a VSX pair. You can connect SW5 to this two switches using MC-LAG. Please also check the VSX guide.
A simple configuration example within the VSX.
interface lag 1 multi-chassis no shutdown no routing vlan trunk native 2 vlan trunk allowed 1-3,5-6,13-15 lacp mode active lacp fallback spanning-tree root-guardinterface 1/1/1 description DOWNLINK_TO_ACCESS_SW_OR_CTRL no shutdown lag 1 mtu 9198
Willem Bargeman
Systems Engineer Aruba
ACEX #125
Original Message:
Sent: Mar 12, 2025 04:56 PM
i am new on Aruba and i am trying some stuff in labor.
i have five switches, the SW5 is connected with SW1 and SW3. On SW5 ist LAG.
SW1 is with SW2 in VSX and SW3 with SW4 in VSX.
in SW1 and SW3 i have MLAG where is the SW5 connected , SW1 and SW3 are also with LAG connected.
i thought MLAG will worked out but the one port is going blocked.
Is that normal? or i forgot something?
Thanks a lot
