  • 1.  MM redundancy over L3 connectivity
    Posted Sep 07, 2019 05:50 AM
    Hi to all,
    do we have any document/reference that explains design and features of MM redundancy over L3/routed topology?
    also, can we do Clustering of MC over L3? how does AP and user redundancy work. I'm thinking of LMS only.
    THank you
  • 2.  RE: MM redundancy over L3 connectivity
    Posted Sep 07, 2019 07:17 AM
    also, how can the two MM manage a single MC over L3?lets say MC1 is same subnet with MM1, in the event that MM1 goes down how can MC do failover to MM2?
    thank you
  • 3.  RE: MM redundancy over L3 connectivity
    Posted Sep 07, 2019 07:46 AM
    Please see the slides here:  https://community.arubanetworks.com/t5/Wireless-Access/Technical-Webinar-Layer-3-Redundancy-for-Mobility-Master-ArubaOS/td-p/382029
    No, there is no clustering over l3. #1 because it is not possible.  That is the situation where you would use backup-lms.
