MM shows in web interface ap which are removed
  • 1.  MM shows in web interface ap which are removed
    Posted Sep 16, 2024 03:32 AM
    Edited by vosske Sep 16, 2024 05:49 AM
    I am trying to clean up old AP's
    on the web interface, select and clicking the bin sometimes does not work.
    clear gap-db ap-name <.....> does the job
    Why can I not remove it with the gui (sometimes? any logic?)
    To make it even worse, some now and then, trying to remove a ap, does work neighter with de GUI nor the clear gab-db does the job!
    even a rebote of de MM after the commands, does not fix my problem
    regards,
    Jeroen
  • 2.  RE: MM shows in web interface ap which are removed
    Posted Sep 19, 2024 08:15 AM
    Edited by mkk Sep 19, 2024 08:14 AM
    What is the version of your Mobility Conductor?
    Maybe check if there is a existing whitelist configured.
    clear gap-db.... should done the job.
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
